When my cars cold
Old Jun 8, 2006 | 06:14 AM
99PreludeSh's Avatar
Default When my cars cold
When i first start my car up in the morning to go to work it always idles so interestinly. The idle will jump for about up to about 2k rpms. Im sure other peoples have done it too. Its been doing it from the factory. SO could this be a bad IAC vavle or what?
Old Jun 8, 2006 | 06:24 AM
SnlpeR's Avatar
you need to check the FITV
and also check and bleed your cooling system
Old Jun 8, 2006 | 06:53 AM
Default Re: (SnlpeR)
FITV is right under the throttle boddy correct?
Old Jun 8, 2006 | 07:05 AM
SnlpeR's Avatar
correctomundo
try screwing the plastic thing in
Old Jun 8, 2006 | 07:08 AM
I shall try that this weekend thanks a bunch!
Old Jun 8, 2006 | 07:29 AM
Lewdin' Incognito's Avatar
Default Re: (99PreludeSh)
I couldn't exactly understand your post. Are you saying the RPM's surge, or it just idles @ 2000rpm?
If it's a cooler morning, mine will idle at 2000 for about 20-30 seconds then will gradually drop down to normal idle. That's normal as far as I know.
Old Jun 8, 2006 | 08:34 AM
Default Re: (Lewdin' Incognito)
haha sorry about that. Im sayinf it jumps up to about 2000 rpms and drops back down to about 800rpms. The dile just goes up and down for about a minute or so.
Old Jun 8, 2006 | 12:03 PM
98vtec's Avatar
moderator emeritus
its either your FITV or you have a bad vacuum leak.
to fix the FITV, you can always block off the coolant lines and loop them back to the thermastat housing.
Old Jun 8, 2006 | 04:40 PM
Hondapreludeg's Avatar
I had the same problem and it was the IAC which the dealer replaced for free since there is a emissions recall. I have a 97 sh and it is covered you may want to call your local dealer and ask if yours is covered under the recall. They trouble shooted everything for free and replaced everything for free.
Old Jun 8, 2006 | 09:15 PM
SnlpeR's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">its either your FITV or you have a bad vacuum leak.
to fix the FITV, you can always block off the coolant lines and loop them back to the thermastat housing.</TD></TR></TABLE>
that will not fix your problem
that is one way to have a surging idle when cold
Old Jun 8, 2006 | 09:17 PM
98vtec's Avatar
moderator emeritus
it will just idle a little higher than normal until its warm. Why would it surge the cold idle? Its not causing a leak.
ahve you never read of people doing the coolant bypass?
Old Jun 8, 2006 | 09:28 PM
SnlpeR's Avatar
a high idle causes a surge too
Old Jun 8, 2006 | 09:29 PM
98vtec's Avatar
moderator emeritus
are we speaking the same language here?
Old Jun 8, 2006 | 09:32 PM
Leo C's Avatar
Night Owl
a cold idle @ 2000 is perfectly normal
nothing to worry about
Old Jun 8, 2006 | 09:46 PM
Leo C's Avatar
Night Owl
Default Re: (apeng09)
700-800 is a normal idle speed
it's perfectly normal for a honda to idle above 1500k when it's cold out.. then drop down to normal idle speed
if the OPs idle speed is fluctuating up and down this could be a symptom of a bad O2 sensor
Old Jun 9, 2006 | 04:27 AM
Default Re: (shutupnskate)
No, he's saying the idle is surging 800-2000 when he starts up.
Old Jun 9, 2006 | 07:36 AM
Yeah it just surges up and down on my idle for about a minute or so. Like they said im going to check my FITV first then my IACV
Stephanie
mike93eh2
Jul 17, 2007 07:45 PM
gregory
Oct 15, 2006 07:15 AM
deeweezy187
Dec 3, 2005 08:50 PM
LudEnthusiast
Jul 5, 2005 10:37 AM
