2006 Accord center console
Old Jun 8, 2006 | 05:35 AM
jaykav99's Avatar
Default 2006 Accord center console
Does any one have instructions on removal of the console, I rather do it correctly in a new car than just take out screws and start pulling on plastic. i have the 06 accord lx special edition 4cyl 5 speed
Old Jun 8, 2006 | 06:00 AM
Ross 2.0's Avatar
In a Junkyard near you.
where the armrest is or below the radio?
Old Jun 8, 2006 | 06:04 AM
jaykav99's Avatar
Default Re: (MooGoCow3)
basically the whole area i need to remove the radio.
Old Jun 8, 2006 | 06:18 AM
02 accord's Avatar
Default Re: (jaykav99)
http://handa-accessories.com/accelect06.html
This site has installation instructions for oem accessories, so look around and I'm sure you will find what you need.
Old Jun 8, 2006 | 06:23 AM
jaykav99's Avatar
Default Re: (02 accord)
I found exactly what i need thanks alot.
Old Jun 8, 2006 | 06:40 AM
Ross 2.0's Avatar
so who are you stealing it from? just kidding
You need to remove the upper vents.
Get a hook shaped tool and hook it onto the outer edge of the vent and pull it towards you (both sides). Once those clips are free then pull the whole thing up and out of the way. (don't need to unhook the sunlight sensor)
Remove the three screws.
Now for the bottom
the shifter trim has clips around it so it just pulls off. Open the "cointray" and pry the tray part out with a flathead screwdriver. remove the two screws under it, pop it out and let it hang by the wires.
remove the two screws at the bottom of the pocket and pull it out by grabbing it on the bottom and top.
remove the two 8mm bolts in the bottom of the audio unit and then the whole thing will pop out (you may need to use a gread deal of force to release the clips)
eagle458
Feb 12, 2013 12:39 PM
sportlead
Sep 4, 2008 05:16 AM
mgalpy
May 13, 2007 07:41 PM
logic
Oct 12, 2003 03:31 PM
crx_ef8
Sep 6, 2003 06:08 PM
