how to: rear seat removal
Old Apr 15, 2002 | 04:09 PM
magic hat #9's Avatar
Default how to: rear seat removal
this question comes up far too often (use the search! ). i have an autopower rollbar on order so i decided to go ahead and start removing the interior.
the carpeting on the back of the rear seats is help on by little plastic pegs, pull these straight out.
one side removed. see the pegs?
both sides done, the carpet will come right out of the car now.
here is the plastic clip you will remove. it's at the bottom of the seat next to the doors, flip the seats down and look for the pin the seatback rotates on.
here is the pin between the seats that the seat rotate on. push the seat towards the door and the seat will pop off the pin.
popping off the seat.
the seat will slide right away from the wall.
with the seat backs removed, on to the seat bottom. remove this bolt, 10mm i think.
once the bolt is removed, grab the seat bottom from underneath the outside bottom edge and give it a yank. it's sideways, but you can see the clip is being pulled out of the white bracket.
you are done. next time i'll remove the rear interior plastic bits and the rear seat belts. i didn't have a metric socket set handy. this whole job will take less than 20minutes - it's VERY easy.
Old Apr 15, 2002 | 04:11 PM
B2FiNiTY's Avatar
Default Re: how to: rear seat removal (monkey_truckR)
This should go in as a FAQ.
Old Apr 15, 2002 | 04:12 PM
done's Avatar
good deal
what exactly is this silver dome with wires emanating from it? i'm guessing tailights, rear wiper, and fuel pump power lines?
Old Apr 15, 2002 | 04:20 PM
D's Avatar
D
fuel pump access.
i still don't understand why people take the carpet off the rear seats in order to remove em..
Old Apr 15, 2002 | 04:26 PM
Default Re: how to: rear seat removal (D)
first timer. i didn't know what to expect so i made it easy on myself. besides, it's easier to store with the carpet removed.
Old Apr 15, 2002 | 04:27 PM
Back in Black's Avatar
Rather OG
Nor do I
Old Apr 15, 2002 | 04:31 PM
AllMotorITR's Avatar
New User
Default Re: how to: rear seat removal (darth vadeR)
I took my carpet off of my rears, but it was not to remove them.. Once my seats were removed I layed the carpet back down... It looks cleaner to me, and is not as noticable as having a trunk of bare yellow metal.
Old Apr 15, 2002 | 04:36 PM
Flux's Avatar
A huge thumbs up to people like monkey_truckR and others that take the time to document these how-to's so people like me can always learn here on Honda-Tech.
Old Apr 15, 2002 | 04:47 PM
D's Avatar
D
Default Re: how to: rear seat removal (Flux)
dood, you just need to spend $60 on a helm manual.
Old Apr 15, 2002 | 04:51 PM
bleh, this is like a book full of pictures. everybody likes pictures, it makes it easier to see what's going on for our non-mechanically inclined colleagues. helms tells you the basics, but sometimes you can get lost without the details. i'd like to see someone do a valve adjustment using only the helms with no outside advice/experience/pictures/description etc.
Old Apr 15, 2002 | 04:56 PM
slowassR's Avatar
how much do the rear seats weigh? is removing them a good idea or only something that need be done when installing a roll cage?
Old Apr 15, 2002 | 05:04 PM
Default Re: how to: rear seat removal (slowassR)
i didn't weigh them, but i would guess about 20lbs. i imagine the seatbelts and plastic bits will remove another 10-15lbs. it's not necessary for the interior to be permanently removed for a rollbar install, but you can no longer use the back seats.
Old Apr 15, 2002 | 05:07 PM
Flux's Avatar
dood, I have one...
I just wanted to thank the people here that help other people instead of making sarcastic remarks.
Old Apr 15, 2002 | 05:57 PM
K1R's Avatar
K1R
Buckle up the rear seat belts.
Old Apr 15, 2002 | 06:01 PM
Dr Pooface's Avatar
Old Apr 15, 2002 | 06:03 PM
B2FiNiTY's Avatar
Default Re: how to: rear seat removal (Torque)
Why?
Old Apr 15, 2002 | 06:04 PM
py1188's Avatar
Default Re: how to: rear seat removal (B2FiNiTY)
very nice how-to
Old Apr 15, 2002 | 06:40 PM
New User
Why?
It's just a style.
Old Apr 15, 2002 | 06:46 PM
Looose_R's Avatar
Default Re: how to: rear seat removal (1 FAST R)
you dont have to remove the rear carpet, why did you?
Old Apr 15, 2002 | 06:55 PM
D's Avatar
D
dood, I have one...
me sarcastic? never.... i'll be watching you... if you ask dumb quesitons easlily answer'd by helms, you get a *******
Old Apr 15, 2002 | 06:56 PM
AssPenny's Avatar
LOL
Old Apr 15, 2002 | 06:58 PM
Type-Rare#1248's Avatar
i needed help on this one!
thank you very much
Old Apr 15, 2002 | 08:05 PM
B18C5's Avatar
Why?
If you don't remove the r3ar belts it keeps them from flapping around. Especially the buckle part. It klangs around under spirited driving. Mine are done up all summer.
Old Apr 16, 2002 | 12:26 PM
Default Re: how to: rear seat removal (B18C5)
the rear seatbelts will be removed from the car soon enough.
i drove the car for the first time without the seats, there is a definite increase in road noise similar to having the windows open 1". i look forward to having the plastic removed as well, i'll be the proud owner of a tin can.
