manual tranny swap?'s
ok so i have what i believe what is all parts needed for a manual trany swap just wanted to see if anyone knows if i do actualy have all of the stuff needed for a swap
all of the stuff came off of a del sol vtec
also wondering if they might fit any other models
heres the list of what i got
peddals gas brake, and clutch
brake booster/master cylender and res.
clutch master cylinder and res.
all of the hard lines for the clutch
thanks for the help
Modified by crvpimpin at 3:42 AM 6/8/2006
thanks for the help
do you have the sol as a donor car? .. i dont think the shift linkage from a sol will work .. what car are you doing the swap on .. do you have the correct mounts?
i had the sol as a donor car
but changed plans and was gonna try and unload this extra stuf so i wanted to see if i had what i needed to make a manual tranny swap
but i have the shift linkage from the del sol
i was pretty sure it would work on an eg but wondering if it would work on an ek too
Do you have a slave cylinder and a transmission and a manual transmission rear engine mount? Those are the only things I see you missing that haven't been suggested yet.
ejv8s10
Sep 3, 2014 11:52 AM
D16vtecfreek
May 7, 2009 11:19 PM
jakeypoo12
Aug 14, 2008 06:52 AM
uszcrx
13
Aug 27, 2006 06:43 AM
uszcrx
Aug 13, 2006 04:34 PM
