Noise & wheel rotation
Old Apr 15, 2002 | 04:01 PM
Quick 200k Mile Motor's Avatar
Default Noise & wheel rotation
Ive been having this problem since last summer, and I probably spent too much $$$$ in parts to try to cure it. Ive used the "Search" to find a post on something like it, but had no luck.
Its a squeak noise ..that only goes with the wheel rotation (wheel speed). Its coming from the driverside front corner. The noise cannot be heard when you're outside. The noise radiates through the chassis. It can only be heard when you're inside. Btw, this is a Teg with a lot of miles on it.
Since I knew the problem occurs with the wheel rotation, I replaced...
*Both front Axles to brand new OE ones (not rebuilt ones),
*Brake Rotors to new Brembo OE blanks,
*Brake Pads to new Hawks,
*Wheel studs,
*and today Wheel Bearings.
All within a 9 month period and I'm still having the same squeak. At this point, its twice as loud. Any ideas of what else it could be?...
[Modified by Quick 200k Mile Motor, 3:18 AM 4/16/2002]
Newstarter
Honda Civic (2001 - 2005)
Jun 8, 2017 07:12 PM
sSandstorm
May 20, 2013 12:19 PM
do0d
Sep 20, 2008 07:53 PM
o0Jash0o
Sep 28, 2006 09:22 AM
carbonlaced
Jun 27, 2006 10:02 AM
