best aftermarket cams on stock valvetrain
Old Jun 7, 2006 | 08:21 PM
b20powereDA's Avatar
Default best aftermarket cams on stock valvetrain
im wanting to know whats the best cams for stock valvetrain? i know i can upgrade valvetrain for relatively cheap and run bigger cams and make more power but thats not what im interested in. im curious as to whats the best cams for stock valvetrain, not oem cams either, i want something aftermarket. ive heard of skunk2 stage1's are pretty good. thanks in advance
Old Jun 7, 2006 | 08:30 PM
ITR#132's Avatar
Spoon?
Old Jun 7, 2006 | 10:13 PM
B18cHatch06's Avatar
Default Re: (ITR#132)
skunk2 stage 1's wont yield much more power than CTR cams...id do with those or BC3's..keeping stock rev limit of course
Old Jun 8, 2006 | 05:24 AM
Nick M's Avatar
Default Re: best aftermarket cams on stock valvetrain (b20powereDA)
I wouldnt use anything but CTR or ITR max.
Old Jun 8, 2006 | 06:13 AM
Teamdiesel's Avatar
BC3+ all the way. Will give you a **** load of midrange.
Old Jun 8, 2006 | 06:21 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: (Teamdiesel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teamdiesel &raquo;</TD></TR><TR><TD CLASS="quote">BC3+ all the way. Will give you a **** load of midrange.</TD></TR></TABLE>
Honestly I thought the BC3+s sucked on my B16. I mean yeah there's a midrange gain, but once you get up top they don't feel very powerful. Almost like stock cams
I'd just do Skunk2 Stage 1s or Toda A (not sure if those are ok on stock valvetrain though)
Old Jun 8, 2006 | 06:31 AM
realis9's Avatar
BC3+ for stock valvetrain.
Old Jun 8, 2006 | 07:24 AM
aZnjCC's Avatar
BC3+ for stock ITR valvetrain
Skunk2 Stage1 for anything else
Old Jun 8, 2006 | 08:00 AM
cute little bastard
Default Re: (KISS ME LUCKY CHARMS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KISS ME LUCKY CHARMS &raquo;</TD></TR><TR><TD CLASS="quote">sorry for hijacking this thread but have just ordered buddy club 3+ for my '97 jdm itr, ive been told by the supplier that to get the most out of them i'll need 12.1 compression, i'm a noob at this stuff & am trying to educate myself through the search, so the questions are
what head gasket?
where can i order 1 online?
if anyone has any info that might help that would be the business </TD></TR></TABLE>
huh? I'm pretty sure you do not need that much compression for the 3+. BC4s yeah. I think you'll be fine with the ITR compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddyClub site &raquo;</TD></TR><TR><TD CLASS="quote">The Spec III Plus camshafts were designed to accommodate a wide range of compression ratios from 10.0:1 to 13+</TD></TR></TABLE>
http://www.buddyclub.us/buddyclub/top_m.html
Old Jun 8, 2006 | 08:23 AM
civicsi0721's Avatar
are you all talking about pro1 or stage 1
Old Jun 8, 2006 | 08:26 AM
cute little bastard
Default Re: (civicsi0721)
regular Stage 1 of course.
Pro 1s are like the regular Stage 2
Old Jun 8, 2006 | 08:58 AM
sheepey's Avatar
BC3+ is more aggressive on valvetrain then you guys think. duration is in the 250-260 at .050 and lift is over .450 on intake and exhuaust. I checked a set I had mid last year and I remember the numbers wer somewhere in there. Exhaust cam did have more lift on it, but the intake had a lil more duration.
Old Jun 8, 2006 | 09:59 AM
Teamdiesel's Avatar
I ordered mine from evasivemotorsports.
Old Jun 8, 2006 | 10:16 AM
thanks for all the info guys. this will be goin on a b20vtec wit aebs manifold, 68mm tb, pos header, and rs machines pistons. head is mildly ported, and hondata im gasket. also has itr valvetrain. another question is, if i go wit bc3+ will i have to grind the valve reliefs in the psitons? im gonna go wit rs machines itr replica pistons.
Old Jun 8, 2006 | 10:24 AM
Default Re: (b20powereDA)
does rocket make anything comparable to the bc3+? does anyon have dyno charts of b20 vtec wt bc3+ in it? a buddy of mine made 214whp on a b20vtec that was pretty simple wit s2s1 cams and stock valvetrain. so its kinda hard as to what to choose. thanks
Old Jun 8, 2006 | 10:34 AM
UncleD's Avatar
Yeah RM makes the M20/M21 cam but I don't know if I would run it on the r valvetrain.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick M &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt use anything but CTR or ITR max.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepey &raquo;</TD></TR><TR><TD CLASS="quote">BC3+ is more aggressive on valvetrain then you guys think. duration is in the 250-260 at .050 and lift is over .450 on intake and exhuaust. I checked a set I had mid last year and I remember the numbers wer somewhere in there. Exhaust cam did have more lift on it, but the intake had a lil more duration.</TD></TR></TABLE>
Both of those^^
Old Jun 8, 2006 | 11:39 AM
sheepey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20powereDA &raquo;</TD></TR><TR><TD CLASS="quote"> another question is, if i go wit bc3+ will i have to grind the valve reliefs in the psitons? </TD></TR></TABLE>
No you wont have to grind anything with the rs piston. You will have more than enough clearance.
Ls_Turboteg
Feb 14, 2009 11:11 AM
1sikcoupe
Jan 17, 2008 06:01 PM
BoostinEJ1
26
Dec 4, 2006 11:40 AM
1sikhatch
May 23, 2006 02:25 AM
1gen crxer
11
Mar 22, 2004 05:01 PM
