Moving fusebox from engine bay to inside glove box
Old Jun 7, 2006 | 06:48 PM
kornerk12's Avatar
Default Moving fusebox from engine bay to inside glove box
Im trying to free up some space and remove the clutter in the engine bay? Anyone done this ? How hard is the wiring for it ?
Old Jun 7, 2006 | 06:53 PM
98vtec's Avatar
moderator emeritus
Default Re: Moving fusebox from engine bay to inside glove box (kornerk12)
you would need to unplug everything from the fuse box and pull the wires through the firewall. Then stick the fusebox in the glovebox...however i dont recall our gloveboxs being big enough for this.
Old Jun 7, 2006 | 06:54 PM
ernestoG's Avatar
Default Re: Moving fusebox from engine bay to inside glove box (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports &raquo;</TD></TR><TR><TD CLASS="quote">when i relocated my fusebox, i didnt read any how-to's...
the best advice i received was to unbolt the fusebox, remove all the plugs from the bottom (each plug only fits one spot), and then try to run the wires inside.
your setup is prolly different than mine or the next guys so it all depends on your car... i dont have a/c so i had a hole right behind the battery to run the wires through.
good luck.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1401203
hope that helps
Old Jun 7, 2006 | 08:27 PM
Hawkze_2.3's Avatar
I have mine under the dash.
Like everyone said, just unplug everything and pull it through to the inside. Then it will make things a lot easier if you buy an el-cheapo grounding kit off of ebay or something because some power wires will have to be extended.
Old Jun 11, 2006 | 01:31 AM
kornerk12's Avatar
Default Re: Moving fusebox from engine bay to inside glove box (Hawkze_2.3)
how do i unplug the wires that are going to the underside of the fusebox ?
Old Jun 11, 2006 | 06:28 AM
jdmlude_dude's Avatar
what glove box? you must have a 5th gen! I would be interested in known if anyone has every done this in a lude
Old Jun 11, 2006 | 07:20 AM
Hawkze_2.3's Avatar
Unbolt the fusebox, lift it up so you can access the wires, then unplug them.
Old Jun 24, 2006 | 05:00 PM
kornerk12's Avatar
So the wires on the underside of the fusebox will pull right out without disconecting anything inside the box ?
Old Jun 25, 2006 | 05:30 AM
kornerk12's Avatar
bump
Old Jun 25, 2006 | 05:14 PM
Hawkze_2.3's Avatar
There's a simple plastic cover that you have to pop off before you can unplug the wires, but yes, they do unplug from the fusebox. Just go out to your car and take a look at it and you'll see it's pretty easy.
Old Jun 30, 2006 | 11:09 PM
kornerk12's Avatar
Ok i have everything apart. Now comes finding a place to run the wires and will they reach ?
Old Jul 1, 2006 | 06:55 AM
kornerk12's Avatar
bump
Old Jul 1, 2006 | 07:14 AM
98vtec's Avatar
moderator emeritus
ur going to have to extend of few of them.
Old Jul 1, 2006 | 07:47 AM
Hawkze_2.3's Avatar
Dude, just go do it. Unplug everything, move the fusebox, run the wires through a hole in the firewall and look and see what needs to be extended.
Old Jul 1, 2006 | 08:48 AM
kornerk12's Avatar
I had everything unpluged yesterday. But i couldnt find anywhere to run the wires.
Old Jul 1, 2006 | 09:07 AM
98vtec's Avatar
moderator emeritus
sometimes you have to do a little work to do things..........
Old Jul 8, 2006 | 11:09 PM
kornerk12's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">ur going to have to extend of few of them.</TD></TR></TABLE>
Is there any easy way of doing that ?
gator88
Dec 14, 2006 02:10 AM
jurenic
Mar 6, 2005 05:20 PM
BDBGoalie1982
Aug 28, 2004 11:22 PM
Fly1865
May 23, 2004 01:26 PM
HamiltonRex
Apr 21, 2004 05:29 PM
