is this gas pedel set up for cruise control, if so can u tell me how please! thanks!!
I think all civic pedals are capable of having CC on them. To make yours CC you need to either buy a whole system or buy one of those universal ones and go from there.
yea that armature on top of the pedal is for cruse control, if you push in on it the gas pedal will go down, there should also be a grommet (or hole) directly behind that arm where the cable comes through the firewall...
you need alot of parts, "auto cruse" computer, actuator, cable, vacume tank and hose etc, the wiring wouldn't be too hard, but how skilled are you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">yea that armature on top of the pedal is for cruse control, if you push in on it the gas pedal will go down, there should also be a grommet (or hole) directly behind that arm where the cable comes through the firewall...
you need alot of parts, "auto cruse" computer, actuator, cable, vacume tank and hose etc, the wiring wouldn't be too hard, but how skilled are you?</TD></TR></TABLE>
What vacumn tank and hoses?.....The cruise is on an electric actuator.
Note*** Speaking about what I my 93 ex has. Don't think Honda would have changed it much.
the 96+have a vacuum line hooked ot it as well all retarded, but to the OP i have a perfectly good cruis control module thing with plug if you want i just took it out of my car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AirForceB16 »</TD></TR><TR><TD CLASS="quote">i think all the wireing is there, i have a cruse switch in the dash, just nothing under the hood?, the switch in the dash is pluged in.. just need the rest.</TD></TR></TABLE>
then someone before you must have just taken out the cruise control, look under the drivers side dash and see if the auto cruise computer is there, and is there a 4 pin plug under the hood (4 wires, 3 brown 1 black, its the exact same plug as your oxygen sensor)
BB6-213
Audio / Security / Video
15
Oct 30, 2006 10:30 AM
