Dead! HELP
Old Jun 7, 2006 | 03:26 PM
B16a92Civic's Avatar
Default Dead! HELP
Ok so i was leaving a parking lot today and going over some speed bumps. When i noticed my cd stopped playing, and when i went to hit the gas my car didnt go.
I tried to restart it. My car did not turn over at all
I drive a 92 civic hatch with a b16 swap. The ecu isnt the p28 i believe.
After that i put my key into the ACC mode. And it did not beep 4 times or so like always.
If you need more information please ask.
Old Jun 7, 2006 | 03:38 PM
slodel's Avatar
Default Re: Dead! HELP (B16a92Civic)
ground wire maybe came loose from the bumps check them all
bump.
Old Jun 7, 2006 | 03:40 PM
Default Re: Dead! HELP (slodel)
ok.
just the ground from the motor to the frame?
cuz my alarm still works
Old Jun 7, 2006 | 03:47 PM
sickvtec's Avatar
Could be ur main relay by ur fuse box under dash
Old Jun 7, 2006 | 03:51 PM
Default Re: Dead! HELP (sickvtec)
ok
i will check it all out
Old Jun 7, 2006 | 04:02 PM
mcgee*'s Avatar
Cigarette Squad
same problem with me man.. cd player isnt turning on like it did before swap, no lights on cluster only seat belt and e-brake...not thread jacking but theirs only 3 ground's in the engine bay right??
FIXED got mine working, i thought my grounds were good.. but they werent that did the trick hopefully for you too
Modified by McGeeTM at 9:23 PM 6/7/2006
yayizzil
Feb 18, 2009 09:30 PM
LSej1
Sep 19, 2007 09:00 PM
xph0b1ax
Jul 16, 2006 05:08 PM
Brok3n
May 20, 2006 08:41 PM
89civichatchback
May 30, 2003 11:55 AM
