Where is the oil pump in a b18a?
Old Apr 15, 2002 | 02:47 PM
vtec69's Avatar
Default Where is the oil pump in a b18a?
I thought that they where in the oil pan. I bought a si oil pump and was planning on putting it in the ls block but I couldn't find anything that looked like the si oil pump in the oil pan.
Old Apr 15, 2002 | 02:50 PM
non-VTEC's Avatar
Default Re: Where is the oil pump in a b18a? (vtec69)
it's bolted to the drivers side of the engine block. you have to remove the crank pulley and timing belt to remove the pump...........
you know the oil pick up inside the oil pan? the oil pump is on the other end of that.......
i hope you have a helms manual.
Old Apr 15, 2002 | 02:57 PM
vtec69's Avatar
Default Re: Where is the oil pump in a b18a? (non-VTEC)
I'm confused
Is it in the oil pan or on the block?
Old Apr 15, 2002 | 04:36 PM
non-VTEC's Avatar
it's machined into the side of the block.......there are 5 or 6 bolts holding it in....you have to remove the crank pulley and timing belt and timing belt covers.....once you remove those you will be stareing right at it.........
Old Apr 15, 2002 | 04:57 PM
frogsr's Avatar
true true...
Old Apr 15, 2002 | 06:15 PM
primoEF's Avatar
the one in the pan is the pick up
allmotor_guys
Jul 11, 2009 07:05 PM
immalooser
May 17, 2006 03:27 PM
snatch
12
Mar 15, 2005 10:12 AM
crazyslowhatch
Oct 17, 2004 10:04 PM
Mefain
May 16, 2003 09:02 AM
