Video of Rear bumper inperfection...
Old Jun 7, 2006 | 02:34 PM
Kamikaze's Avatar
Default Video of Rear bumper inperfection...
Want to know how to fix this.... Only the rear bumper, the front's been fixed.
http://www.youtube.com/watch?v=k9WAwJ2NAWM
I've put the screw in, it's in real tight, I also noticed that the rear splash guard was removed, so there's only one screw holding it to the body on the left and right side...
Old Jun 7, 2006 | 02:39 PM
projectTeG's Avatar
you remove the taillights
someone prolly backed into something and warped the bumper. you can try unscrewing the screws and adjusting it.
Old Jun 7, 2006 | 02:41 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Video of Rear bumper inperfection... (Kamikaze)
Almost looks like it wasn't put on right, you have to take out the tails, and rear filler panel below them to get to the bumper.
Old Jun 7, 2006 | 02:55 PM
Kamikaze's Avatar
OK, I'll wait until I get my new tail lights, and when I take the others off, I can do all of those in one day, Yeah, i went to a body shop and the guy was wanting to charge me like $200 to readjust it, so I figured I'd try it myself. But it looks like it can be fixed and I won't need another one or what do you guys think?
Old Jun 7, 2006 | 02:58 PM
Hype-R Stalker
Default Re: (Kamikaze)
I doubt the bumper is the problem, it's probably just jammed on something.
Once you take off the interior panels on the inside to access the nuts for the tails, and such.
The ones for the rearfiller panel are 10mm, 4 on each side, then like 8-9mm for the tails,
When you get those off, you'll see how everything fits with the bumper, and should be able to fix it.
Old Jun 7, 2006 | 06:50 PM
Tizight's Avatar
euro tail lights blah
Old Jun 7, 2006 | 09:02 PM
mxl36o's Avatar
my left side also doesn't clip on. underneath the rearlights is a clip, that corner isn't clipped on, either cause it wont go back on, or you haven't tried clipping it back on. It it wont clip back on, you can goto http://www.acuraoemparts.com, and buy the clip $5.
Old Jun 8, 2006 | 08:01 AM
Kamikaze's Avatar
Exact same thing, I looked, and you can see where that clip isn't on, and it's pushed back some, so just lifting the bumper won't fix it. But the clip is still on there though. So i'll probably just end up taking off the entire rear bumper when I get my tail lights in, thanks guys for the help. Also, I noticed that when I see the clip there, I also see where there's screws, and those aren't coming from the inside of the car, they look like they were just screwed right into the bumper and not through the trunk to the bumper.
Old Jun 8, 2006 | 08:28 AM
Hype-R Stalker
There's a metal lip under the bumper that those screws go into.
Old Jun 8, 2006 | 08:31 AM
Nors's Avatar
Wow, this is pretty funny actually. My Accord has all the same exact damage. The rear bumper damage was caused by a truck thinking he could "make it" out of a paralell parking spot, so he pushed my whole bumper down. Never been able to get it fixed, well without paying anyways. I have the same exact gap under my tailights which gradually gets tighter. The front my "bolt dealie" or whatver you/video maker, called it is also gone so thats the reason for the damage there. I do not think it will be hard to adjust, but if the bumper has damage, you may be out of luck.
Old Jun 8, 2006 | 09:51 AM
Kamikaze's Avatar
Doesn't look like theres any damage at all to it. That's crazy that this video I made and all these people are having the same problems lol.
Old Jun 8, 2006 | 10:01 AM
ECKOTYPER's Avatar
hehehe simply thnigns can fix all of that just think a little bit... aslo go back to stock when u remove the taisl to fix the rear bumper
Old Jun 8, 2006 | 10:31 AM
Kamikaze's Avatar
Nope, not going to stock, going to these...
http://cgi.ebay.com/ebaymotors...sting
Old Jun 8, 2006 | 01:43 PM
ECKOTYPER's Avatar
might as well go to UKDM spec, at least some flava, but those ones u showed me are way better then b4
Old Jun 8, 2006 | 02:12 PM
renegadez7o7's Avatar
From: flatlandz CA 7o7 But Now In Phoenix AZ, AZ and CA, usa
OEM 98 +
cybersec
Jul 6, 2017 06:22 AM
CD7Modder
Jan 22, 2012 09:23 AM
omehegan
Oct 27, 2004 02:07 PM
90civichb
Feb 12, 2003 07:39 PM
