Clutch related problems.....95 GSR
Old Jun 7, 2006 | 01:37 PM
jonshonda's Avatar
Community Builder
Default Clutch related problems.....95 GSR
The DL: 95 GSR w/ 103,000 on her and the clutch..Problem: First 2" of pedal travel on the clutch are worry free and smooth, and from that point there is resistance(not too much) and it feels like somthing is binding up(almost like a rusty cable on cable transmission) After that 2" you can also hear the master cylinder squeaking and making noise. All fluids are filled, and clutch does not slip. LMK what you people think
Old Jun 7, 2006 | 03:25 PM
jonshonda's Avatar
Community Builder
ttt
Old Jun 7, 2006 | 05:49 PM
akstunt600's Avatar
Default Re: (jonshonda)
bad master
slaves hardly ever go bad and it ovious whe they do, they will leak or fail completely
Old Jun 8, 2006 | 03:14 AM
jonshonda's Avatar
Community Builder
Default Re: (akstunt600)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akstunt600 &raquo;</TD></TR><TR><TD CLASS="quote">bad master
slaves hardly ever go bad and it ovious whe they do, they will leak or fail completely</TD></TR></TABLE>
That is what i was thinking, no sign of leaks inside the car, and fluid levels seam to be staying up. Any other input would be great.. Should i go with oem master of do aftermarket suppliers make a decent replacement??
Old Jun 8, 2006 | 09:34 AM
95 JDM GS-R's Avatar
Default Re: Clutch related problems.....95 GSR (jonshonda)
SOUNDS TO ME LIKE THE MASTER CYLINDER ALSO!!! I HAD THIS PROBLEM ABOUT TWO WEEKS AGO. I BOUGHT TOKICO AFTERMARKET SLAVE AND MASTER CYLINDERS FROM NOPI.COM GOOD PRICING AND IT FIXED THE PROBLEM I WAS HAVING WHICH WAS JUST LIKE YOURS. ONLY TOOK ABOUT 30 MIN TO DO BOTH!!!! I HAVE A 1995 GS-R B18C1 ALSO, GOOD LUCK
Old Jun 8, 2006 | 11:14 PM
jonshonda's Avatar
Community Builder
thanks 4 the hep guys,looks like i am in the market 4 a master. im drunk
hondastudent1on1
37
Jan 28, 2010 10:23 AM
tempname
Sep 27, 2007 05:54 PM
wardseg6
Feb 15, 2007 01:42 PM
NeWnMpR0VeD
Jun 17, 2006 11:46 AM
delsolb16
13
Oct 1, 2005 11:09 AM
