Spoon B18C (Dont look if you have a weak stomach)
High Compression Spoon B18C + Loose Timing Belt + Iran/Taliban with heavey foot from excessive sand in shoe = BOOM
[Modified by PhoBichNga, 11:26 PM 4/15/2002]
Sorry Pat ... I waited cause I figured you would and when I saw that you didn't I executed
It came out of a ITR and the guy who did was just an FOB nothing else ... it must of been funny to see his expression though when the thing started making funny noises at 10,000 RPM
WHAT A WASTE
[Modified by PhoBichNga, 11:49 PM 4/15/2002]
WHAT A WASTE
I think you've got a loose valve.... just do an adjustment and she'll run like new
Sorry about the mess, but now it gives you that upgrade you've allways wanted to do....
what the hell happened to it?
Mis-shift? The horror....
What the he11. Why did he not shut the car off when he heard something strange.
Here are some pic of my motor when one of my cams broke. As you can see, there is significantly less damage than the motor above. He must have been a smokin' something to keep running the motor
[Modified by canuck-mx6, 12:30 AM 4/16/2002]
Man it's all good. I think if he put the cyl. head back on.... and like somebody mentioned...did a valve adjustment...maybe use some PROLONG... it'll be all good!
Hell, if he used PROLONG from the beginning, this coulda been avoided!
horror yes....i won't even try to imagine what it sounds like when it happens
