Smoke coming from fuse box during wire tuck
Hello, Im having a damned problem w/ my wire tuck. Im doing the Driver side of my 89 EF Si Hatch.
While just routing wires and doing each one at a time. I forgot to ground the lil ground wire box, I noticed smoke coming from by the Turn Signal Clicker box on the inside driver side fuse box. I cant get it to Signal or Hazards to work. Driver side everything works fine. No fuse was blown either. Anyone have any ideas what it could be. I got the constent to light up, just dont get a signal..
Thanks in Advance and any info is appreciated.
last time i had this happen a fuse was blown. I would go and recheck fuses under the dash and the engine fuse box again. Something is def blown.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ccivics »</TD></TR><TR><TD CLASS="quote">replace the blinker module</TD></TR></TABLE>
hmm lets see how much Honda wants for that thing.
yeah junkyard, actually I might have one. it's raining out so i'll check tomorrow. grounds are definetly the most important thing, everything you take out remember to put back
post up your pix of the progress on the tuck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_ef3 »</TD></TR><TR><TD CLASS="quote">yeah junkyard, actually I might have one. it's raining out so i'll check tomorrow. grounds are definetly the most important thing, everything you take out remember to put back
post up your pix of the progress on the tuck!</TD></TR></TABLE>
They in the last few pages of my project thread.
https://honda-tech.com/zerothread?id=1001119
Just wanted to say the blinker module still makes the blinking sound though... thanks for all the input peeps!
post up your pix of the progress on the tuck!</TD></TR></TABLE>They in the last few pages of my project thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9295EJ-t »</TD></TR><TR><TD CLASS="quote">there are 2 filaments in the blinker bulbs... you could have simply burnt out the blinker filament??? look at the bulb</TD></TR></TABLE>
I swapped out bulbs already, aint the bulbs
hatchyboy89
May 4, 2012 07:42 PM
