How to timing belt tensioner
Old Jun 7, 2006 | 07:04 AM
trevor72's Avatar
Default How to timing belt tensioner
Just want to say thaks to all those that helped me diagnose my headgasket. That's what it ened up being even though the compresion was still within spec. I'll get some pick up in my old post probably by thursday.
Hopefully this isn't a stupid question:
==How does the timing belt tensioner tension? Where do I put a wrench to 'turn' it out of tension? It seems to be locked. Is this normal? Isn't the bolt in the front middle of the tensioner for taking it on/off not applying tension/un-applying tension? Or is it? Guess I'm just not seeing it clearly right now.
Trevor
Old Jun 7, 2006 | 07:24 AM
instructor74's Avatar
Default Re: How to timing belt tensioner (trevor72)
the bolt on the front of the tensioner locks it in place. just loosen the bolt a little bit so the tensioner can move freely. there should be a spring that connects from the tensioner to a pin on the block (if I remember correctly). Once you have the new timing belt and water pump in (don't bitch about it just do the water pump it will save you big $$ in the long run). You turn the motor Counter clockwise 3 timing belt teeth then re-tighten the bolt to factory spec. double check the manual for the exact way of doing this. When you turn the motor CC it puts slack in the timing belt near the tensioner and lets the spring pull the tensioner in for the correct amount of tension. cool isn't it
Old Jun 7, 2006 | 08:03 AM
trevor72's Avatar
Default Re: How to timing belt tensioner (instructor74)
wow I'll have to read that a few times over, great info thanks. And ya I already bought a new WP and it's ready and waiting to be assigned to my block
does 0.8 on the top of my piston mean that the motor has been bored? there are more letters but can't recall them at the moment.
Old Jun 7, 2006 | 08:11 AM
Your welcome one last thing you should think about replacing the tensioner just to prevent any problems down the rood there like $25
Old Jun 7, 2006 | 09:55 AM
EE_Chris's Avatar
Another timing belt thread with scanned 99-00 Si Helms images.
yankie_1132
Apr 17, 2012 03:33 AM
methos713
May 5, 2008 08:01 PM
supracrx
Feb 17, 2008 09:06 AM
B!^A@
Aug 14, 2006 09:24 PM
KoRE
Jun 15, 2002 09:27 AM
