Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Honda 2006 (tow package) no running lights?
Old Jun 7, 2006 | 06:56 AM
edthecatcher's Avatar
Default Honda 2006 (tow package) no running lights?
i just installed a tow package onto my 2006 Honda Ridge line. The wiring for this package seemed to the point, and infact, everything works (turn sig left / right - brakes, etc) on my trailer with the exception of my running lights- any ideas?
BTW. I tested to insure my trailer wasn't a problem by hooking my trailer up to my 2003 Yukon-- all of my test passed.
Old Jun 7, 2006 | 08:37 AM
Honda318dx's Avatar
Default Re: Honda 2006 (tow package) no running lights? (edthecatcher)
People with early models had problems with the reverse lights. What is your build date? Could the fuse have blown accidentily?
Old Jun 7, 2006 | 09:07 AM
Ross 2.0's Avatar
In a Junkyard near you.
did you install the relay in the dash?
Modified by MooGoCow3 at 10:18 AM 6/7/2006
Old Jun 8, 2006 | 06:55 AM
Default Re: (MooGoCow3)
Hi and thanks for the quick reply-- i did check all fuses and there were non blown at time of installation or post install (test ok).. as for the build date- i'll have to check.
Old Jun 8, 2006 | 06:56 AM
Default Re: (edthecatcher)
thnk you for the quick responce-- i did install the relay- but you may have brought up a good point as i think there were two relays- maybe i installed the wrong one-- i'll test.. thanks
srcv4life
Apr 21, 2013 07:25 PM
LB CRX
Honda CR-V & Element
Jun 26, 2011 05:14 PM
Clairvoyant
Aug 5, 2006 09:45 AM
typeshb
Aug 13, 2002 09:13 PM
