issues with ep3 fog lights install
Old 04-17-2013, 02:01 PM
srcv4life's Avatar
Default issues with ep3 fog lights install
OK so I was installing my 02 civic si fog lights today. I connected all the cables inside and sent the wire to the from to test the fogs before installing them. I turned on my headlights and the button lit up and I pushed the button on and you can hear the relay clicking on when I do it and the fog light sign lights up but my fog lights don't turn on. What could be the problem?
Old 04-17-2013, 04:30 PM
srcv4life's Avatar
Default Re: issues with ep3 fog lights install
I check all the wiring and I followed all the directions not sure what I'm missing. Is there a way on how to test if there is volts going to the front wiring harness?
Old 04-19-2013, 05:56 AM
DC5/EP3 MOD :)
Type-Spaz's Avatar
use a volt meter.
Old 04-19-2013, 05:59 AM
speedooo's Avatar
Originally Posted by Type-Spaz
use a volt meter.
Volt meter to test voltage? Get out of here with that nonsense.
Old 04-21-2013, 04:07 AM
lazlong's Avatar
^^ No tech post in the tech forum is the real nonsense. With over 13,000 posts I'd think you'd have read the FAQs.
Old 04-21-2013, 07:09 PM
SiK20A3's Avatar
Ground wire ??
Old 04-21-2013, 07:25 PM
lazlong's Avatar
Yeah, it could be a bad ground if everything works but the actual lights. Are you getting voltage at the light sockets?
Mitch Hopper
12-02-2017 08:29 AM
benji7288
12-29-2007 08:33 PM
Iboot
03-13-2007 02:46 PM
Mark Murda
11-05-2004 12:43 PM
4DRmafia
07-12-2004 10:51 PM
Quick Reply: issues with ep3 fog lights install
