need some help folks
ok, as some people know i got a crx with a b18b1 in it that has a 11.1 compression ration. I want to get rid of the high compression so i can boost it. I was thinking about getting some low compression pistons and leaving the head i have on there now. (shaved 30 thousandths and has mild port and polish) I'm stuck though because a friend said that if i leave the pistons in and put a stock head my compression will be 10.5, and that gsr's and type r motors are higher and get boosted all day.
So, now is where i need some help.
Should I :
1- Leave type r pistons in and get a stock head and get more power from less boost.
or
2-Put stock or lower compression pistons in with the shaved head or stock head and have more reliable car and something i can put lots of boost on.
Thanks,
Jake
Should I :
or
Thanks,
Jake
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J4k3 »</TD></TR><TR><TD CLASS="quote">ok, as some people know i got a crx with a b18b1 in it that has a 11.1 compression ration. I want to get rid of the high compression so i can boost it. I was thinking about getting some low compression pistons and leaving the head i have on there now. (shaved 30 thousandths and has mild port and polish) I'm stuck though because a friend said that if i leave the pistons in and put a stock head my compression will be 10.5, and that gsr's and type r motors are higher and get boosted all day.
Should I :
or
Thanks,
Jake</TD></TR></TABLE>
option 1.
Should I :
or
Thanks,
option 1.
#1!
Simply cause it's easier, and cheaper. LS heads go for next to nothing. Most people throw them out after an LS VTEC swap, which produces a scrap B16 block and a scrap B18A head. Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">#1!
Simply cause it's easier, and cheaper. LS heads go for next to nothing. Most people throw them out after an LS VTEC swap, which produces a scrap B16 block and a scrap B18A head. Good luck.</TD></TR></TABLE>
lol i got a complete 98 LS head given to me from a shop. had burnt exhaust valves. i was like, ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">
lol i got a complete 98 LS head given to me from a shop. had burnt exhaust valves. i was like, ****. </TD></TR></TABLE>
I have been given LS heads from 2 different shops. Now I have 5 LS heads sitting around, I used one as a test bed so I only have 4 good ones left. So option one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">
i didnt need that many LS heads laying around considering all the other bullshit that was in my garage
</TD></TR></TABLE>i didnt need that many LS heads laying around considering all the other bullshit that was in my garage
Exactly, hence why I have used them for test beds and given them away. Too much BS in the shed already.
</TD></TR></TABLE>Exactly, hence why I have used them for test beds and given them away. Too much BS in the shed already.
Exactly, hence why I have used them for test beds and given them away. Too much BS in the shed already. </TD></TR></TABLE>
turn em into ear rings
