CYP CODE 9 - Have 130ohms at all 3 sensors in dist & no continuity
Old Jun 7, 2006 | 05:59 AM
Si Shane's Avatar
Default CYP CODE 9 - Have 130ohms at all 3 sensors in dist & no continuity
I measured ~150ohms in each sensor (cyp, tdc, and the other). I also checked for continuity to a ground, and get nothing. I'm not sure if I need a new dist or if I'm doing the test wrong.
Thanks for your help.
When I do this test: For the resistance test I am using a new battery in my meter and I place the electrodes on the terminals for the CYP sensor. I get a reading of 150-0ohms depending on my calibration switch. Helms spec is 350-700 or so.
For the continuity I place the negative electrode on either the chassis or neg of the battery and the pos on one of the terminals for the CYP sensor.
I get aboud 150ohms for the 3 sensors in the dist, and none have continuity. I checked my vtec pressure solenoid and it offered a reading of .5ohms or so when I checked continuity.
Old Jun 7, 2006 | 08:15 AM
JimBlake's Avatar
Default Re: CYP CODE 9 - Have 130ohms at all 3 sensors in dist & no continuity (Si Shane)
Those sensors in the distributor are magnetic, so the resistance check is only sorta good. Most times a bad sensor will fail the resistance check. But it's possible for a bad sensor to have OK resistance. It's also possible for the star wheels down in the distributor to be screwed up or ???
Don't forget to check the wiring back to the ECU. The ECU can't tell the difference between a bad sensor vs. a broken wire.
That would be the VTEC solenoid valve, right? The VTEC pressure switch should be open circuit when the engine's not running.
Old Jun 7, 2006 | 05:37 PM
Chiovnidca's Avatar
Default Re: CYP CODE 9 - Have 130ohms at all 3 sensors in dist & no continuity (JimBlake)
Checking connector pins for fit and corrosion would be a good idea too.
sinceasar
Jan 25, 2013 04:17 AM
clubworkz
Sep 26, 2011 12:59 PM
crxnonvtec
Aug 20, 2009 02:40 PM
SlowHX
Jun 8, 2005 07:53 AM
se93
Sep 23, 2003 07:25 AM
