Built turbo LS/VTEC ITR, what head gasket?
Old Jun 7, 2006 | 01:26 AM
racingfan's Avatar
Default Built turbo LS/VTEC ITR, what head gasket?
hey, whats up? HT
I have a 2000 ITR with built turbo LS/VTEC motor in it, I knew the head gasket is about to blow.. so I stop driving the car untill I find out which head gasket should I use, the block has been bored out to 86mm.. so my question is: should I run OEM honda B16 head gasket?
Old Jun 7, 2006 | 02:13 AM
Circuit Star-29's Avatar
Default Re: Built turbo LS/VTEC ITR, what head gasket? (yellowitr_06)
Why not call Mike and ask him what gasket he used...
Poor R...
Old Jun 7, 2006 | 04:33 AM
RTW DC2R's Avatar
why would you use an 81mm gasket on an 86mm bored block? Pistons will probably hit the gasket. If the LS/VTEC is set up properly, you could probably go with a B20 gasket (bored to 86, but coolant/oil holes might not line up properly on the head) or an B16/ITR gasket bored to 86mm(again, check coolant/oil holes). Youll probably have better luck with this in the Hybrid forum. Personally I would probably go with the B16/ITR gasket and bore it to 86.
Old Jun 7, 2006 | 06:12 AM
D-Rob's Avatar
Default Re: (clip the apex)
Golden Eagle re-worked 86mm LS headgasket, FTW.
Old Jun 7, 2006 | 10:01 AM
racingfan's Avatar
Default Re: Built turbo LS/VTEC ITR, what head gasket? (Circuit Star-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">Why not call Mike and ask him what gasket he used...
Poor R...</TD></TR></TABLE>
I've tried call him.. but his phone is off for a while and haven't re-turn my call yet..
it has blown head gasket the first day I bought the car...
Old Jun 7, 2006 | 10:07 AM
Do you know how to install a new headgasket? Call golden eagle and pick up one of there headgaskets...If you need installation done, gimme a call. You can come check out the new shop.
360-441-5151. I screen my calls so leave a messege if I dun answer.
Golden Eagle...
909-592-4311
909-599-4692
sales@goldeneaglemfg.com
Old Jun 7, 2006 | 10:15 AM
racingfan's Avatar
no I haven't never done isntall a new headgasket.. but I'd love to learn how to do that stuff.. actually I just talked to crescent yesterday thinking about get the ITR re-tune and dyno.. so I might just carry the new headgasket with me when I go up there have crescent do it as well.
krazych0p
Nov 10, 2008 01:38 PM
maddcrx
Jul 22, 2008 03:55 PM
90Rexx
Feb 24, 2008 06:41 PM
eh2-hb
Oct 13, 2005 10:01 PM
mh
Dec 14, 2003 01:07 PM
