Cant shift reverse
Old Jun 6, 2006 | 10:40 PM
Wheelman-CZ's Avatar
Default Cant shift reverse
Still the same car, still the same friend, still some problem
We have changed the inlet shaft tranny bearing becouse the tranny was huming, huming stops but now its hard to shift the reverse gear. Other gears are OK, just the reverse. Its hard to move the shift **** to gear up the reverse.
Also his stearing wheel is shaking when accelerating.
He has bad front motor mount, can be this the problem or where can be a problem?
Thank you for your help!
Old Jun 6, 2006 | 11:20 PM
project 2two9's Avatar
Default Re: Cant shift reverse (Wheelman-CZ)
u might just need a new tranny... and for the wheel shakeing situation, u could check yours axles or basically anything on your front suspension...
Old Jun 8, 2006 | 02:54 PM
We dont want new tranny. Before we have changed the bearing everything was OK, just the humming, today is humming gone but problem with shift :-(
Old Jun 8, 2006 | 03:00 PM
sohc88rex's Avatar
Your saying it wont shift into reverse at all ? Have you tried putting it in second then
reverse? My car sometimes doesnt wanna go into reverse either, but I use that put it in
second trick then try reverse again. It always works after that
Old Jun 8, 2006 | 05:10 PM
shortyz21's Avatar
Default Re: Cant shift reverse (sohc88rex)
when u put it back toghether u fucked something up. imo that humming noise is typical and i seen cars go 200 000 kms with that noise with no ill effects
if its a D series, buy another they are cheaper then blowers
snatch
12
Jul 16, 2004 03:42 PM
snatch
Jul 11, 2004 03:58 PM
servion
Feb 9, 2003 08:12 PM
boomslang
Nov 18, 2001 12:00 AM
