93 ls b18a1 obd1 injectors w/ 95 gsr wiring. do you need a resistor box?
Old Jun 6, 2006 | 08:24 PM
sled's Avatar
Default 93 ls b18a1 obd1 injectors w/ 95 gsr wiring. do you need a resistor box?
ok. i have a 95 honda civic hb cx. needed a new car harness so i replaced it with a 95 gsr car harness and a 95 gsr motor harness. the motor in the car for now is a 93 ls obd1 and my question is my friend told me that i need to run a resistor box. i cant remember if it had one when i yanked the motor out of the car. i do know even though the 93 ls is supposed to be obd1 and the motor harness from the 93 ls wouldnt match up to the 95 gsr car harness. so i switched motor harnesses to the 95 gsr one. my situation........ 93 motor, with 4 good injectors with no resistor box. and i have 3 good 95 ls ingectors due to the fact that the 4th one got cracked. are they the same injectors? i guess i could do a partnumber crossreference at a part store. its just 11:38 pm so nothing is open...lol
ok i dont know if any of that made sence. i dont want to run a resistor box. i guess my ? is can i use the 93 ls injectors or should i just buy a 4th good injector from the 95 ls to be able to run no resistor box.
Old Jun 6, 2006 | 09:03 PM
RPRacing's Avatar
you are ok to use the 93 injectors, they are obd1 therefore saturated, therefore do not need a resistor box
Bigkev616
Oct 17, 2009 06:18 AM
95civicB16
May 1, 2007 02:04 PM
JDM Vision
Jun 25, 2006 01:23 AM
not so civic
Jul 2, 2001 10:41 PM
