AFTER ITR swap, no more AC~~???
did ITR swap a while ago..
test AC yesterday didnt' work.... the AC fan doesnt turn at all
so took it to the shop today.. the machnic told me it's something to do with the ECU
since ITR ACs are optional so if the swap i bought didnt' have AC then AC in my car will not work.. is that true?? it's 98 USDM ITR swap i bought
thanks
thanks
noooo, that is complete and total b/s
a/c is chassis electrical controlled and NEVER see's the ecu side of the car
make sure the one wire plug for the compressor is plugged in, and double check the fuse.
least likely scenario> when whoever did the swap if they left the a/c in car an pulled th motor around it, they might have kinked the metal and lost the gasses
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akstunt600 »</TD></TR><TR><TD CLASS="quote">noooo, that is complete and total b/s
least likely scenario> when whoever did the swap if they left the a/c in car an pulled th motor around it, they might have kinked the metal and lost the gasses</TD></TR></TABLE>
thanks for the replies guys..
so waht should i do now?? the AC fan isn't turning.. and i do not hear the compresor click either..
usually when the AC is turn on i can hear the engine tone changing like RPM goes low than high.. but no more that now.. basically, AC switch isnt' doing anything now..
any ideas??
any ideas??
b_boy190
May 21, 2024 01:24 AM
