I did a compression test in my GSR.............
Old Jun 6, 2006 | 05:51 PM
GDM93Si's Avatar
Default I did a compression test in my GSR.............
I need to Know if the compression is good????? the motor is bone stock and i got 165 across
Is that the what it suppoust to have???
Old Jun 6, 2006 | 05:52 PM
Aquafina_Powered's Avatar
Default Re: I did a compression test in my GSR............. (GDM93Si)
consistency
Old Jun 6, 2006 | 06:16 PM
GDM93Si's Avatar
So 165 is perfect on the dot.. thats what its suppoust to have??
also is the USDM GSR
Thx everyone
Old Jun 6, 2006 | 06:26 PM
cambopheonix56's Avatar
Default Re: (GDM93Si)
Might be consistant, but if you should have 220ish or more..
Old Jun 6, 2006 | 06:27 PM
Default Re: (cambopheonix56)
Redo it with WOT, fuses pulled and must be at operating temp. I am assuming you didn't do one of those things.
Old Jun 6, 2006 | 06:32 PM
GDM93Si's Avatar
I unplug the main relay, and the car was at full throte all spark pugs out at the same time and temp was at operation....... something wrong
so it should not be at 165 across
Modified by GDM93Si at 7:42 PM 6/6/2006
Old Jun 6, 2006 | 06:38 PM
ek_99_SiR's Avatar
wot will help
Old Jun 6, 2006 | 06:44 PM
GDM93Si's Avatar
i did have it at WOT>>>> oh my god im going to go boost 2morrow this is so fustrating..
Old Jun 6, 2006 | 06:46 PM
Did you replace the stock pistons with lower compression pistons?
Old Jun 6, 2006 | 06:52 PM
A.E Motoring's Avatar
how many cranks you do it? with 5 cranks i get 185-190 across and with 7 cranks i get 210-215 across, try doing it again
Old Jun 6, 2006 | 09:37 PM
GDM93Si's Avatar
I did a 4second rotation I holded the started for 4sec like 1.. 2.. 3.. 4.. then let go
Old Jun 6, 2006 | 09:59 PM
gold_ef's Avatar
let it turn over 5 times
Old Jun 6, 2006 | 10:00 PM
GDM93Si's Avatar
about how long is that just to have an idea
Old Jun 6, 2006 | 10:08 PM
gold_ef's Avatar
you can hear the starter cranking
Old Jun 6, 2006 | 10:09 PM
well u can hear the cranks, count 5 see where its at, then do it 7 times see where your at, and try adding a cap size of oil in the cylinders see if the compression goes up
Old Jun 6, 2006 | 10:15 PM
GDM93Si's Avatar
could it be the gauge guys cuz damn i just did it again and i did the same 165 and in every cyllinder.....
Old Jun 6, 2006 | 10:20 PM
could be the gauge, try a differnet one,
take a look at this
http://www.c-speedracing.com/h...t.php
Old Jun 6, 2006 | 10:23 PM
GDM93Si's Avatar
Ohh maybe is this the problem i have a turbo kit on could that be,
So the air has to trable from the turbo, intercooler and the pipes
Old Jun 6, 2006 | 10:27 PM
not shouldnt be it, cause i have a turbo on my car too, try a differnet gauge, then try the wet test, are u doing this car normal operating temp?
Old Jun 6, 2006 | 10:29 PM
GDM93Si's Avatar
yea
MarkCayabyab
10
Oct 29, 2013 06:18 PM
hawaiieg6
Jul 15, 2009 08:57 AM
Dev15Bizz
May 2, 2007 08:19 PM
bustdgst
Jan 26, 2007 01:05 AM
GsrIntegra789
Oct 9, 2006 12:14 PM
