75 shot on a b16
Hey im new to this whole thing do u think its safe to spray a 75 shot of zex on a b16 in a 99civic si i needa kno and what all i should do to be on the safe side some 1 please help
A 75 shot on a B16 should be ok, just make sure you get set of colder spark plugs and you should be good. Make sure the motor is in good working order before you run nitrous through it though. So a good tune up would be a good idea...just to be on the safe side
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skylinetph26 »</TD></TR><TR><TD CLASS="quote">A 75 shot on a B16 should be ok, just make sure you get set of colder spark plugs and you should be good. Make sure the motor is in good working order before you run nitrous through it though. So a good tune up would be a good idea...just to be on the safe side
i agree, it should be ok if the tuning is good, some bigger injectors will help alot as well as race gas.
</TD></TR></TABLE>i agree, it should be ok if the tuning is good, some bigger injectors will help alot as well as race gas.
