97 Civic HX check engine light came on, shift lights turned off
Old Jun 6, 2006 | 03:25 PM
dj_matthias's Avatar
Default 97 Civic HX check engine light came on, shift lights turned off
I just bought my used 97 Civic HX. It got hot the other day, so I turned my A/C on. As i kept driving, my check engine light came on, my shift lights stopped working, and my cars idle went up and down. I turned my A/C off and the idle evened out and the car runs fine. But now my check engine light is still on, and my shift lights don't work(not that I care about the shift lights) What is the deal? Anyone?
thanks,
dj_matthias
Old Jun 7, 2006 | 05:39 PM
Kiid's Avatar
Default Re: 97 Civic HX check engine light came on, shift lights turned off (dj_matthias)
it is just over heating or something..
Old Jun 7, 2006 | 06:51 PM
khodey's Avatar
im gonna guess oxygen sensor. just a guess.
Old Jun 7, 2006 | 06:54 PM
pdiggitydogg's Avatar
you guys...i swear... just guessing isnt going to help...
check the code:
http://www.hstuners.com/forums...23007
and using your a/c will make the idle fluctuate a bit
Old Jun 8, 2006 | 03:31 AM
CivicTunin's Avatar
go with pdiggitydogg's advice, if the check engine light came on then run a ECU diagnosis
Old Jun 8, 2006 | 03:48 AM
VRD^don's Avatar
Default Re: (CivicTunin)
jump the service connector and count the blinks..longer blinks=10count (2 long blinks=20) short fast blinks=1count (2short fast blink=2)..then use the link that pdiggitydogg provided you to see what code u are throwing..
tylerzero
Honda CR-V & Element
Oct 27, 2022 07:21 PM
kecil
10
May 9, 2011 11:35 AM
gtec28
May 18, 2007 07:13 AM
