setting timing question...help QUICK!!!
alright the chilton manual says to jumper a (green/wite)(one wire) and brown connector to set the timing.......the problem is, i cant find these color wires....i have a 2 terminal open plug with brown and black.......and there is also a 3 wire connector......it's the worng color wires too.......is this 2 wire terminal the correct one to jumper..i believe the car is canadian too......so maybe the colors are differnet? any help anyone?
no, it says to jumper a 2 wire connector..and i dont wanna jumper it and blow the ecu.........is it a blue connector?
there's a 2 wire connector and a 3 wire connector, i plan on using a timing light to check it, i just need to know if it's the right connector.....is it a blue plug wiht a green plastic insulaton over it. is it the 2 prong or 3 prong connector. it's a 1994 civic ex, d16z6
Oh, I misread, my bad. You jump the 2 wire connector<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">You jump the connector thats by the pass kick panel to check your ecu. Then use a timing light to see where your at. </TD></TR></TABLE>
94CoupeEJ1
14
Jan 1, 2013 01:59 AM
