d16z6 swap question
I am going to be doing a d16z6 swap with an si tranny into my 92 civic vx which still has a d15z1 and vx tranny in it.
I am wondering what I all need to change out to do the swap. Will my wire harness for the z1 work on the z6?? What about my axle shafts?? I also plan on getting a p28 ECU if that makes a difference. These are both OBD1 right???
How about my alternator also??
Thanks a bunch in advance
i beleive everything will work. the only thing i am not to sure about is the harness. but i wouldnt see why it wouldnt, it is already wired for vtec..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG_GSR_HB »</TD></TR><TR><TD CLASS="quote">I am going to be doing a d16z6 swap with an si tranny into my 92 civic vx which still has a d15z1 and vx tranny in it.
Thanks a bunch in advance</TD></TR></TABLE>
The only thing I see having the need to convert is the 4 wire O2 sensor that's in your car right now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG_GSR_HB »</TD></TR><TR><TD CLASS="quote">SO D15Z1 IS 4 WIRE AND D16Z6 IS 5 WIRE??</TD></TR></TABLE>
the z6 is a 4 wire and the z1 is a 5 wire
SO ITS A PRETTY SELF EXPLANATORY(SP) SWAP THEN, AND PRETTY MUCH PULL OUT THE MOTOR AND TRANNY AND DROP NEW ONES IN.
THANKS GUYS...
WILL THE Z1 WIRE HARNESS PLUG INTO AN P28 ECU
THANKS GUYS...
kKdARIAN
May 31, 2005 11:48 AM
pdcivic
11
Aug 3, 2003 06:56 PM
