Air Conditioning Compressor Bearing Part # inside....
After having a bearing in an Air Conditioning compressor clutch fail, I started to look for a new one. You can only buy the complete clutch from honda, and it is nearly $150+. After a lot of searching, I found the part.
It is a 35mm inner, 50mm outer diameter bearing that is 20mm wide.
NACHI part # 35BG05S7G-2DST
NSK # 35BD5020DDUCG21
The bearing is about $27. I ordered one from "The bearing Place" in texas (1-800-535-9638) However, your local bearing place might have the part as well.
I think this bearing is for all sanden compressors, and may even fit other brand compressors.
So if your compressor bearing makes noise and is failing, here is a low cost alternative to replace it!
