how does sea foam work
You can put a small amount in your oil. I ran half a can in a half gallon tank of gas, then I filled the tank up and put more seafoam in it after I filled up. I would recommend you do it on a high mile motor, runs it through your brake booster line VERY slowly or you could hyrdolock apparantly. I didn't have any problems with my motor but I've heard that it can burn your 02's out if you run too much of it at one time. I sold the motor shortly after I did it anyways but it still ran good if not better than before the Seafoam.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trick_db »</TD></TR><TR><TD CLASS="quote"> they say use 1/3 of each
Yeah, i do gas tank, oil, and brake booster.
</TD></TR></TABLE>Yeah, i do gas tank, oil, and brake booster.
iono i have a 4 door integra on the cluster is says 161k. but i bought the car of some dude. is a b20 and i have no clue on the mileage on it. should i use seafoam for it? or not. since i does not noe the mileage on the b20
yea i mite try it. not sure maybe 1/3 of it? or 1/4? what you prefer lan? did it make a big difference on your motor? **** i rather do it make it run better but dont wanan risk it if you noe what i mean
I know what you mean... Do you have an aftermarket FPR on the car? If so, crank the PSI up a little and go with a 1/3 if not try a 1/4. I would recommend you put about 1/3 of it in your gas tank too, but I might wait a gas fill up or twp until I ran it through the brake booster line
my car are stock. no nothing. if i can find a better way to do it safely then i will do it. i dont mine, just that the fact that ppl done it before, some get hydrock? and some expletive up their bearing. so im just scare. but i noe what you mean tho.
i'd recommend doing a search for seafoam. This has been covered numerous amounts of times just in the integra forum. I did a quick search in the archives and it came back with 26 hits, all talking about what your asking, pics, how to's, problem of hydrolocking, etc. I wouldve linked you to all the threads but that just wouldve taken too long.
central_driver
Jul 9, 2006 03:45 PM
