HELP2!!!!
Old Jun 6, 2006 | 12:04 PM
signman's Avatar
Default HELP2!!!!
CDMNG
(trial)
Offline
3 posts [100%]
BENTON Arkansas
6-4-2006
Help!!!! « » 7:35 PM 6/4/2006 Reply Edit
I have a 97 civic lx that has some issues. It is throwing a lean code. I have changed the fuel pump, filter, water temp sensor, sparkplugs and the wires. I have installed a cold air kit as well as a header. My gas mileage has gone to hell. the weird thing is that when the engine is cold it runs fine, but when it gets up to running temp it has no power it idles rough and if you are driving at a constant speed the car falls on its nose but if you either give it more gas or let off the gas the power comes back. I have had the fuel pressure as well as the timing checked and both are fine. Both me as well as my mechanic are stumped. If any one has a suggestion it will be appreciated.
kKdARIAN
Arrrrr!
Offline
2988 posts [100%]
Not Here Nor There Tx
9-20-2002
My Gallery « Re: Help!!!! (CDMNG) « » 7:36 PM 6/4/2006 Reply Edit
have you tried swapping out o2 sensors with another car to see if maybe thats your problem?
"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones".
-Albert Einstein
CDMNG
(trial)
Offline
3 posts [100%]
BENTON Arkansas
6-4-2006
« « » 7:41 PM 6/4/2006 Reply Edit
I was told that an o2 sensor would throw a specific code.
kKdARIAN
Arrrrr!
Offline
2988 posts [100%]
9-20-2002
My Gallery « Re: (CDMNG) « » 7:53 PM 6/4/2006 Reply Edit
When i read you were running lean and having bad gas mileage, that was the first thing that comes to mind. It wont hurt you to try borrowing someones o2 sensor for a quick 15min test to see if that fixes your problem. Won't cost you a dime either if you know someone with the same setup as you.
Also maybe you've got some dirty old injectors. What is the mileage of your car and what motor are you running?
-Albert Einstein
JDMikEj8
Offline
258 posts [100%]
So. Cali Ca
11-24-2005
« Re: (kKdARIAN) « » 8:31 PM 6/4/2006 Reply Edit
Quote, originally posted by kKdARIAN »
Good advise!!
Vtec Mike
Vouches: B18chatch83, Spoonspeed, sleepingEj8
FS: JDM EG Hatch tailgate
92-93 Grey EG Dash
Apexi VAFC II With Box and harness
OBD II - OBD 1 jumper harness
NGK SOHC VTEC plug wires
Solfood's TFR So. Cal meet https://honda-tech.com/zerothread?id=1646785
. M i c h a e l
Offline
2664 posts [94%]
Poconos PA
1-26-2000
« Re: (JDMikEj8) « » 8:55 PM 6/4/2006 Reply Edit
Quote, originally posted by CDMNG »
not always. if the o2 has completely went to crap it'll throw a code, but sometimes if its just on its way out...no code will show.
also, perhaps its an ECU issue?
Anyone think it might be staying in open loop mode?
http://www.furgift.com
For all your handmade gift needs. Rugs, Pillows, stuffed animals and more! PM me!
Tires, JDM sidemarkers and DA Integra parts for sale
You should probably bump this thread for me, i'd really appreciate it
Car audio that you KNOW you want to buy
CDMNG
(trial)
Offline
3 posts [100%]
BENTON Arkansas
6-4-2006
« « » 9:03 PM 6/4/2006 Reply Edit
I have 178000 miles on the car. I also use injector cleaner regularly.
I have now tried the O2 sensors and they did not work. Any more suggestions?
Leander003
Honda Civic (2001 - 2005)
Oct 26, 2018 09:16 AM
einzelherz
Dec 20, 2013 10:56 AM
XxJDMugenCivicxX
14
Feb 15, 2007 02:50 PM
CDMNG
Jun 4, 2006 08:03 PM
eric_97ex
Sep 1, 2005 09:50 AM
