ways to remove scale build up between water jacket???
Old Jun 6, 2006 | 10:26 AM
95EXf22vtec's Avatar
Default ways to remove scale build up between water jacket???
i need help..... i recently stripped my f22a1 block bear and cleaned every thing up but before i rebuild it i want to clean out the water passages i tried pressure washing it but scale still remains.... id like to be able to clean it without having a machine shop remove my sleeves any help would be great.....
Old Jun 6, 2006 | 10:59 AM
b18bturbo's Avatar
Default Re: ways to remove scale build up between water jacket??? (95EXf22vtec)
you can use CLR
get it from your home supply and or grocery store. Its clearner to remove the water deposits
Old Jun 6, 2006 | 11:07 AM
nvm on this topic i figured out a great solution to this prob.....for those of you in the same situation, take a .22 rifle cleaning kit for the tight spaces between the sleeves and for the angled areas i found a 12 gauge kit works great but be careful not to scratch the cylinder head mating surface or accidentaly scrath the cylinder bore...............
Old Jun 6, 2006 | 11:09 AM
Default Re: ways to remove scale build up between water jacket??? (b18bturbo)
hmm CLR didnt think of that... do you think that it would work better than the gun cleaning kit or would it be best to use both thx for the info......
Old Jun 6, 2006 | 11:22 AM
b18bturbo's Avatar
take a clr in cup and use a stee brush like you use to clean through holes and stuff.
4dek
22
Dec 24, 2010 02:23 PM
gizzmo222
Detailing
Jul 8, 2010 10:06 AM
ejLday
Detailing
Mar 25, 2009 08:54 PM
1slowcrx
Paint and Body
15
Jan 27, 2008 09:05 PM
SoSoJeff
Jul 12, 2004 12:15 PM
