ECU finding way back to normal with vafc?
Old Jun 6, 2006 | 09:56 AM
Speed Infliction's Avatar
Default ECU finding way back to normal with vafc?
One of my friends told me that every day I drive my car the computer tries to find its way back to normal with the vafc. He said that it would not happen with hondata or other programable ecus. Is this true and if it is about how long would it take the ecu to find its way back?
Old Jun 6, 2006 | 10:10 AM
SecretAgent's Avatar
yes and no.
Old Jun 6, 2006 | 10:14 AM
Default Re: (SecretAgent)
can you explain?
Old Jun 6, 2006 | 02:55 PM
cjames235's Avatar
Default Re: (Black Mamba)
yes it does on the stock ecu and no it doesnt on programmable ecus (hondata, etc)
Old Jun 6, 2006 | 02:56 PM
cjames235's Avatar
Default Re: (cjames235)
best way to get around it is reset the ecu everyday
Old Jun 6, 2006 | 06:10 PM
jetydosa's Avatar
25 Year Member
Could someone elaborate on how the stock ecu will begin to correct itself to compensate for a VAFC? And what evidence they have that this is true?
Just curious.
Old Jun 7, 2006 | 09:24 AM
how do you reset the ecu?
Old Jun 7, 2006 | 10:09 AM
realis9's Avatar
i would also like to know too.
Old Jun 8, 2006 | 08:30 AM
Default Re: (jetydosa)
The factory ECU has fuel trim adjustment tables that will correct themselves based on O2 sensor readings. However, if you tuned ur VAFC/SAFC properly ur O2 sensor readings will still be within spec, and the ECU won't have to compensate. This only applies to normal driving, anything over 80% throttle is an open loop situation where the ECU doesn't read the O2 at all and goes purely off a preconfigured calibration.
Old Jun 8, 2006 | 08:33 AM
realis9's Avatar
so apexi vafc has some use if it is tuned right?
Old Jun 8, 2006 | 10:12 AM
hey are you from houston secret agent?
Old Jun 9, 2006 | 08:34 AM
Default Re: (realis9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 &raquo;</TD></TR><TR><TD CLASS="quote">so apexi vafc has some use if it is tuned right? </TD></TR></TABLE>
no. because even though it allows you to fool the ECU into adjusting the fuel maps (only withinn factory specifications) it gives you no control over timing. In fact, it changes timing in a way that you can't control and can possibly make the car run worse than when you started. Just because the fuel mixture is correct, doesn't matter because the timing could be off by up to 20 degrees. The *AFC modfies the MAP sensor signal to compensate fuel trims. When it modifies this signal it tricks the ECU into thinking there are different parameters, so it will use a different part of the fuel map. However, these different parameters also cause the ECU to use a different timing map.
For the same price, and a little more in tuning, you can have a Hondata S100, with total control over what your ECU is doing and how your car runs. The *AFC is fine for cars that there is no other economical tuning device available or if the factory ECU's parameters are generous enough to still allow the car to make decent power gains from the addition of it (i.e. supras). For a Honda, they don't make any sense.
Old Jun 9, 2006 | 09:26 AM
jetydosa's Avatar
25 Year Member
So if this is true why are there gains made on the dyno using the vafc? Is it bc you are only talking WOT and open loop on the dyno?
b18-eg6
Aug 1, 2006 05:23 AM
inzane
Nov 21, 2005 12:36 AM
moekhanafer
May 13, 2005 07:48 PM
Tarlacon
Apr 4, 2005 03:49 PM
Richard.
Nov 23, 2003 12:36 PM
