Removing an alarm - questions.
Old Jun 6, 2006 | 05:28 AM
Surestick's Avatar
Default Removing an alarm - questions.
Is this a DIY job for a relative newbie?
What's involved?
Old Jun 6, 2006 | 06:25 AM
B18C_EJ8's Avatar
All that's involved is tracing each wire back to it's connection, cutting the connection and insulating with tape. If there's starter kill hooked up, you'll need to reconnect the starter wire that was interrupted.
Old Jun 6, 2006 | 11:49 AM
Surestick's Avatar
Default Re: (B18C_EJ8)
So the alarm isn't wired in to the wiring harness in series it's wired in in parallel, except for the starter wire?
That should make it easy.
Thx.
Old Jun 6, 2006 | 11:54 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">So the alarm isn't wired in to the wiring harness in series it's wired in in parallel, except for the starter wire?
What? Most alarms are installed by simply splicing into the existing wiring, or "t"ing into the wire...
Old Jun 6, 2006 | 11:10 PM
bpr0422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">What? Most alarms are installed by simply splicing into the existing wiring, or "t"ing into the wire... </TD></TR></TABLE>
"t"ing the wire.. is wiring in parallel.. sorta
Old Jun 7, 2006 | 01:32 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (bpr0422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">
"t"ing the wire.. is wiring in parallel.. sorta </TD></TR></TABLE>
You have the right idea yes. Make sure you reconnect the starter wire.
Old Jun 9, 2006 | 10:56 PM
imadigitalgod's Avatar
"t"ing the wire.. is wiring in parallel..</TD></TR></TABLE>
tac22
May 22, 2009 12:30 AM
jweller
Audio / Security / Video
Feb 2, 2007 07:38 AM
enwycee
Dec 11, 2004 08:29 AM
lildrgn2.0
11
Aug 5, 2004 07:05 AM
