...reving skunk2 pro1 cams...
Old Jun 5, 2006 | 07:56 PM
knowledg321's Avatar
Default ...reving skunk2 pro1 cams...
i have the pro1s in my gsr and run 290cc prelude injectors...runs fine...powerband is low though...starts to dip down after 8k so i shift at 8.5k to stay in vtec...i want to rev higher...any suggestions? will bigger injectors do it or thats just how the cams are? comp. ratio is at about 11.3 ...im thinkin about getting stage 2 cams instead...my car is for track use and it feels like the pro1 cams arent doin too good...
Old Jun 5, 2006 | 09:50 PM
B18cHatch06's Avatar
Default Re: ...reving skunk2 pro1 cams... (knowledg321)
is the car even tuned? or just tuned enough to idle?
Old Jun 5, 2006 | 10:01 PM
Default Re: ...reving skunk2 pro1 cams... (B18cHatch06)
yes its tuned by a very reputable tuner...i made about 195 whp and 130ish trq...could it be that it was tuned on toda headers then i switched it out to an rmf but dint get it retuned?
Old Jun 5, 2006 | 11:51 PM
Combustion Contraption's Avatar
At what RPM did you make peak power?
Old Jun 6, 2006 | 01:09 AM
UncleD's Avatar
Default Re: (Combustion Contraption)
Pro1's are not a peaky camshaft. They are known more for making midrange power, if you want more top end I would suggest a RM M22x and shift around 9.2.
Old Jun 6, 2006 | 07:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">At what RPM did you make peak power?</TD></TR></TABLE>
i made peak power at 8k den it drops from there...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Pro1's are not a peaky camshaft. They are known more for making midrange power, if you want more top end I would suggest a RM M22x and shift around 9.2.</TD></TR></TABLE>
how much do those go for? are they known for more top end and for good track use...i was lookin at skunk2 stage2 cams or the buddy club IVs
Old Jun 6, 2006 | 08:12 AM
Dat1BVtecN's Avatar
I've heard or pro 1's makin power up to 9, maybe a little pass 9. Maybe a better tuner and ECU would help. Pro 1's are just like the Stage 2's but the Pro 1's have larger primary lobes which increases the midrange power but harder to tune.
Old Jun 6, 2006 | 08:24 AM
Default Re: ...reving skunk2 pro1 cams... (Dat1BVtecN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dat1BVtecN &raquo;</TD></TR><TR><TD CLASS="quote">I've heard or pro 1's makin power up to 9, maybe a little pass 9. Maybe a better tuner and ECU would help. Pro 1's are just like the Stage 2's but the Pro 1's have larger primary lobes which increases the midrange power but harder to tune.</TD></TR></TABLE>
yea dey do make power past nine i think from wat ive seen here on h-t...if you have a higher flowing head with a p&p and a 2.0 block...anyone have a 1.8 makin peak power up to at least 8.5?
my build consists of:
gsr motor and trans oem headgasket
tuned on neptune
os jdm itr pistons
stock valves
skunk2 pro1 cams
skunk2 intake manifold
str 68mm tb
rmf header
rsr gtII exhaust
12.5 flywheel and exedy clutch
aem rail and reg.
Old Jun 6, 2006 | 09:17 AM
UncleD's Avatar
It is extremely rare to see Pro1's make power past 9k, I think I've only saw it once. There was just a thread on here that we were discussing that, I think Tbone's motor had them making power at 9k....but that was a very healthy motor. The M22's are known for their top end, it's not unusual to see them making power to 9k or above and are a great drag race cam. The Pro1, due to the fact that it has more midrange, would be a better auto cross camshaft.
Old Jun 6, 2006 | 10:09 AM
DonF's Avatar
Default Re: ...reving skunk2 pro1 cams... (clean rice)
You can always retard the intake cam to make numbers higher and give up some mid.
Old Jun 6, 2006 | 11:15 AM
Dat1BVtecN's Avatar
Default Re: ...reving skunk2 pro1 cams... (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">You can always retard the intake cam to make numbers higher and give up some mid.</TD></TR></TABLE>
really, cool is that true? can anyone back that up?
Old Jun 6, 2006 | 11:35 AM
UncleD's Avatar
Anything that Don says you don't need to have backup. Don is a very wise person, listen to him and learn from one of the best.
Old Jun 6, 2006 | 12:27 PM
thanks for the advice...anyone else has some input to this?
Old Jun 6, 2006 | 12:52 PM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Anything that Don says you don't need to have backup. Don is a very wise person, listen to him and learn from one of the best.</TD></TR></TABLE>
1.8L_allmotormilitia
May 8, 2007 07:02 PM
J1A1H
26
Dec 18, 2006 07:09 AM
Dat1BVtecN
30
May 10, 2006 08:49 AM
rodimus
86
Mar 23, 2005 10:46 AM
2ndgent3g
Nov 4, 2004 02:06 PM
