Engine Mis-fireing Check engine light codes (71-74)
Old Apr 15, 2002 | 10:14 AM
TurboB18C1's Avatar
Default Engine Mis-fireing Check engine light codes (71-74)
Yea just bought a greddy kit for my 98 integra Gs-R and i have everything installed and when i started my engine it had a werid *** idel and while on the tes run it died out 4 times with the check engine light blinking. I got the codes from jumping a wire and it was saying 73,72,74,71 and i looke them and it said cylinder 1,2,3,4 are mis fireing.
I checked all my injectors and they work, i double checked all the vacum lines and nothing leaks, the only thing i think the problem could be is the FMU. I have a apexi VAFC hooked up to it and then hooked that up to my OBD 2. Also i am using splices to wire things to gether.
Old Apr 15, 2002 | 10:23 AM
Pinhead's Avatar
New User
Default Re: Engine Mis-fireing Check engine light codes (TurboB18C1)
I think you killed your sparkplugs
Old Apr 16, 2002 | 12:02 AM
quickspoolin's Avatar
Most of the gsr greddy kit users have this problem. I also have had this problem for about a year and it seems not to put my car into limpmode. I pretty sure that the wires from the injector clips just need to be soldered and shrink wraped. I would also take out the VAFC cause that might be causing your car to stall ,cause mines never stalls out.
Old Apr 16, 2002 | 12:42 AM
Kamin's Avatar
Default Re: Engine Mis-fireing Check engine light codes (quickspoolin)
check your firing order and spark plugs.
also double check your timing.
SleeperGSR
Jul 15, 2007 10:05 AM
decode22
Nov 5, 2005 10:04 PM
Fizzader
Oct 4, 2004 04:25 PM
originalbadbob
Jun 24, 2004 10:17 PM
TurboB18C1
Apr 15, 2002 10:18 PM
