High RPM
well you can always get a different final drive or one person put in a 5th gear from another tranny
that wouldn't mean getting a different tranny
but it would be much easier just slapping on a f22 tranny
or the obvious
DRIVE SLOWER
or the obvious
DRIVE SLOWER
I have a plan for my car wich involves shorter final gear + much wider 5th gear from an other tranny or even custom
I if i can do that it would be the best for me... shrto 1-4 gears for racing and wider 5th gear for high way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 »</TD></TR><TR><TD CLASS="quote">well you can always get a different final drive or one person put in a 5th gear from another tranny
or the obvious
DRIVE SLOWER</TD></TR></TABLE>
Did someone do that for a H series tranny or was it a B..I rember reading a thread where someone did that but I thought it was a B series.
Link me up buddy cause I'd love to read it..and give it a try...getting those RPMs down on the freeway would make me just a little bit happy
and for the OP yeah I think this would be your only choice. or yeah slow down..
ok edit there seems to be mixed opinions on fiting the F series 5th into an H tranny...off to read more..
I rember the thread I was thinking of it was a B series and the guy put in an LS 5th..maybe an option shorter 1-4 and a tall 5th. I wouldnt really want much shorter gearing though then what I have....except 5th
Modified by ernestoG at 10:40 PM 6/7/2006
or the obvious
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92piece »</TD></TR><TR><TD CLASS="quote">ya i figured getting a new tranny was the easiest, or at least most feasable
thanks for the advice</TD></TR></TABLE>
the easiest way to lower rpms for any speed would be to buy some blinging 22's....
i do believe someone has done it, i saw the post. but i think it was preludeonline (if you have an acct you could view) but its not really worth the trouble.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernestoG »</TD></TR><TR><TD CLASS="quote">
Modified by ernestoG at 10:40 PM 6/7/2006</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign »</TD></TR><TR><TD CLASS="quote">
the easiest way to lower rpms for any speed would be to buy some blinging 22's....</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phateless »</TD></TR><TR><TD CLASS="quote">hate to point out the obvious, but you could always get 17s?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phateless »</TD></TR><TR><TD CLASS="quote">ok i'm guilty, i skimmed.</TD></TR></TABLE>
HAHAHA you are forgiven
do some math as to how long it will take you to save enough money from improved gas mileage to offset the cost of putting a taller 5th in. and it was b series trannies that people do the LS 5th into a gsr/itr/b16 tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92piece »</TD></TR><TR><TD CLASS="quote">what do you mean "17s"?</TD></TR></TABLE>
inches in diameter of rims to get, a larger overall diameter rim+tire than stock rim+tire will reduce the rpm for any given speed, a smaller diameter rim+tire than stock will increase rpm for any given speed
