11.5 c/r w/87 gas possible?
Old Jun 5, 2006 | 04:29 PM
Anti-Drama Queens's Avatar
Default 11.5 c/r w/87 gas possible?
i just did my swap...but before i did it i forgot all about the gas and luckily only have about a 1/4 tank left....so do u guys think it is safe to drive on...once it starts up, ill be driving it to a tuner right away but just wondering would that be ok for the motor?...its a 81.75 gsr block with aftermarket jdm itr pistons , buddy club spec 3+ cams, 64mm throttle body, blox manifold, rc310, 255lph fuel pump running on a chipped p28, chipped by phearable.net
if anyone has almost the same set up or if anyone who has experience with these types of build, where do u guys think the fuel pressure should be set at?
Old Jun 5, 2006 | 05:49 PM
96Spec Ek's Avatar
Default Re: 11.5 c/r w/87 gas possible? (mr_ducksauce)
45psi, and why not just fill it up with some 93 now if its only got a 1/4 tank of 87
Old Jun 6, 2006 | 02:59 PM
just afraid some will sttill be stuck in the fuel lines and stuff...and was just wondering if its like really dangerous or something....dont wanna blow up the money pit
Old Jun 6, 2006 | 03:05 PM
existanzcivicb20's Avatar
Default Re: (mr_ducksauce)
drain the gas tank and add new fuel into it and prime the fuel pump a few times
Old Jun 6, 2006 | 03:08 PM
DonF's Avatar
Default Re: (existanzcivicb20)
Are 5 gallon cans that expensive?
91cb7h23
Feb 10, 2013 04:13 PM
hybrid2007
Welding / Fabrication
12
Feb 19, 2009 03:13 PM
r3v da t3g
Oct 23, 2006 06:37 PM
allhonda
Sep 25, 2006 04:17 PM
