release and pilot bearings
got a type r pressure plate to put into my jdm j1 tranny cause of pressure plate issues (suspected). the disc is a clutch masters 3rd stage carbon kevlar segmented one. since my tranny is cable would the type r bearings fit or do i have to get one from a da 90-93 teg. looked on the faq but got nothing. priced the parts and the cost the same. thanks all.
ok, thanks for the input so in that case since all the pilot bearings are the same i should just get the bearings for the DA teg?
I have a cable B series clutch release bearing if you are looking for one. I ordered the wrong one when i bought mine. It's brand new and unused. I have a hydro tranny so I have absolutely no use for it. PM if you are interested
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Old Renegade »</TD></TR><TR><TD CLASS="quote">ok, thanks for the input so in that case since all the pilot bearings are the same i should just get the bearings for the DA teg?</TD></TR></TABLE>
ya but remember you've got the smaller input shaft. i'm not sure if it makes a difference on the throwout bearing or not, so get 90-91 to be safe
will do so just to be on the safe side thanks for the guideance. cant wait to get back in my hatch and roll. one!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Old Renegade »</TD></TR><TR><TD CLASS="quote">cant wait to get back in my hatch and roll. one!</TD></TR></TABLE>
might as well smoke it too then
:-) did some research and found that 90-93 teg release and pilot bearings are the same ie part # 910006-634-008 "pilot bearing" 22810-ps1-015 "release bearing". although 90-91 clutch disks are the same, but 92 and up are the same which differs from the 90-91. 90-91 carries two types of disc part # 22200-pr3-030 and 22200-pr4-020. 92-up teg carries two types of disks part # 22200-p72-005 and 222000-p72-015. hope this helps anyone with my dilema or any clutch issues.
Just waiting for my parts to come in "release and pilot bearing" and i should be ready ride out. about how long do you guys thinks to break in the pressure plate? when i had my clutch kit setup i drove it for 1k before i got on it.
thedudefromjerz
Aug 8, 2008 11:58 AM
V-SPEC 1
May 19, 2007 07:45 PM
meagainsttheworld
Sep 4, 2006 03:23 PM
hybrid1990crx
Feb 20, 2005 05:58 AM
