Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Legend overheating and loosing coolant?
Old Jun 5, 2006 | 02:40 PM
ENJOI's Avatar
Default Legend overheating and loosing coolant?
i have an 89 legend that wasnt passing emissions, it now overheats after about 15 minutes of turning it on, and i have to add coolant... any ideas? i need to know if this motor is worth keeping or just say expletive the car if its a blown headgasket, thanks guys i know honda-tech will come through again
Old Jun 5, 2006 | 09:44 PM
CompanyFlow's Avatar
Default Re: Legend overheating and loosing coolant? (ENJOI)
Check your hoses. If it isnt that then your headgasket is b-l-o-w-n
Old Jun 6, 2006 | 06:27 PM
CmptchAV6's Avatar
Default Re: Legend overheating and loosing coolant? (CompanyFlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow &raquo;</TD></TR><TR><TD CLASS="quote">Check your hoses. If it isnt that then your headgasket is b-l-o-w-n </TD></TR></TABLE>
From the post I would have to agree that it is most likly going to be a blown head gasket. If it were a leaking radiator, leaking water pump, leaking hoses, or leaking heater core you would notice antifreeze on the ground when the car is parked or on the floorboard of the passenger side, but you didnt notice that and I can only think of 1 other place the antifreeze could be going and that is into the cumbustion chamber.
Old Jun 6, 2006 | 10:18 PM
Default Re: Legend overheating and loosing coolant? (CmptchAV6)
I was thinking that maybe the thermostat is stuck closed, but its a longshot.
Old Jun 7, 2006 | 01:41 PM
CmptchAV6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking that maybe the thermostat is stuck closed, but its a longshot.</TD></TR></TABLE>
yeah but if that was the case he shouldnt need to add fluid to it because the fluid would just endlessly cycle through the engine. I dont see anything but a BHG from this in all reality and if it has gotten in the H range a few times the heads are most likely going to be warped as well. Luckly though the C27A is a pritty cheap engine and the JDM version with low miles can be found pritty regularly on Ebay for pritty cheap.
Here is one I found right now in a quick search: http://cgi.ebay.com/ebaymotors...ZWDVW
Old Jun 14, 2006 | 01:27 PM
alpine_hikr's Avatar
no if your thermostat gets stuck closed then your coolant will overheat and boil thus causing the loss of coolant. I have never seen a blown headgasket on any legend prior to 91' in 3 years of working at an acura dealership. I would pressure test your cooling system and check for leaks. If none are found I would toss in a thermostat. If its still over heating then check for hydro carbons on your coolant overflow if you have access to a 5 gas analyzer. Good luck
Old Jun 15, 2006 | 09:44 PM
ikeray's Avatar
check your dipstick. see if the coolent is seeping into the engine heads and thus would be in your dipstick. signs of bhg is a really milky oil, or a really oily coolent. the overheating and coolent levels COULD be unrelated though, say you have a leaky hose radiator, and your fans arent clicking on. a bhg on a first gen legend is rare, VERY rare, so i would check the signs first. also check at acura-legend.com and see if you can dig up some info there, that is board is always booming with great info on these cars!
integranewb
May 7, 2007 02:12 PM
giantdny
Nov 6, 2006 07:13 AM
ondahush
10
May 19, 2006 10:14 AM
B16 ED9
Feb 5, 2005 06:02 PM
kevin96GSR
Feb 3, 2004 06:41 PM
