Car Overheating
The needle from the temperature gauge almost climbs immediately to about 3/4 of the temperature gauge. When I accelerate quickly, it falls back to around the middle. Also if I put the a/c on full Heat, the needle drops. I popped the hood and noticed that only 1 of the 2 fans on the radiator was spinning, is this the problem? or is it the thermostat?
yeah, it's real easy...You'll need to get some more anit-freeze. It sits on the passanger backside of hte motor. Just follow the big hose that runs from the bottom of your radiator to the back
Yes it is...it'll wrap around your thermostate. Be sure to place it back in correctly, cause it says which side goes upward and there are little groves on the backside of the gasket in which it needs to be placed back in....If anything, use your old thermostat as a reference
JDM_CRX_PLEASE
Feb 1, 2008 03:30 PM
