MSD SCI Plus Install *** Where are you guys mounting it ??
Old Jun 5, 2006 | 01:16 PM
lude98SH's Avatar
Default MSD SCI Plus Install *** Where are you guys mounting it ??
I was going to install my MSD but i couldnt really find a spot to mount the thing in the engine bay. Anyone else have this ignition any help would be appreciated ?
Old Jun 5, 2006 | 02:13 PM
Leo C's Avatar
Night Owl
Default Re: MSD SCI Plus Install *** Where are you guys mounting it ?? (lude98SH)
a lot of ppl mount the unit+ coil in the space near your intake. I've also seem em mounted along the firewall.
FYI msd ignition is not really necessary w/ a stock engine. my car felt like it lost power with a 6al+ blaster ss coil. I sold it to some guy w/ a Camaro.
Old Jun 5, 2006 | 02:22 PM
lude98SH's Avatar
Default Re: MSD SCI Plus Install *** Where are you guys mounting it ?? (shutupnskate)
Yes i know its not necessary but a friend of mine had it for cheap and i wanted a 2 step and this has one built in
Old Jun 5, 2006 | 02:28 PM
Leo C's Avatar
Night Owl
well just to give you a heads up it won't make any power on a stock engine and switching to an external coil is actually a way to lose power on a stock engine, the stock ignition is more than ample.
mount it where your intake box would normally be( i'm assuming you have an aftermarket intake that freed up some space in your engine)
good luck
Old Jun 5, 2006 | 02:49 PM
BlueLude94's Avatar
Aftermarket ignition isn't really neccarsy till about 400hp.
Old Jun 5, 2006 | 03:07 PM
lude98SH's Avatar
Default Re: MSD SCI Plus Install *** Where are you guys mounting it ?? (BlueLude94)
haha ... yea i know its not necessary i was just asking where anyone mounted it. and the 5th gens come stock with an external coil.
Old Jun 6, 2006 | 08:18 PM
DIRTYsouthBB6's Avatar
I f you go to AutoZone and spend about 50 bucks on a Civic/Integra-sized battery ( group 51 ), then you should have some space right in there due to the reduction of battery size.
Old Jun 6, 2006 | 09:23 PM
Hawkze_2.3's Avatar
Mount it as far away from heat as you can. My MSD POS died after a short period and I don't think having it mounted on the firewall helped any.
Old Jun 7, 2006 | 11:42 AM
lude98SH's Avatar
Default Re: (DIRTYsouthBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRTYsouthBB6 &raquo;</TD></TR><TR><TD CLASS="quote">I f you go to AutoZone and spend about 50 bucks on a Civic/Integra-sized battery ( group 51 ), then you should have some space right in there due to the reduction of battery size.</TD></TR></TABLE>
I have an optima yellow top and would definitly want to keep that.
Old Jun 7, 2006 | 12:12 PM
tcontesh's Avatar
Default Re: (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueLude94 &raquo;</TD></TR><TR><TD CLASS="quote">Aftermarket ignition isn't really neccarsy till about 400hp.</TD></TR></TABLE>
That is correct the best ignition until that point is oem.
You will spend more time and money in the long run just to lose power and reliability.
Modified by tcontesh at 4:23 PM 6/7/2006
00cvcSI
Aug 28, 2007 08:44 PM
landon
Jul 25, 2004 01:09 PM
clemsoncb7
Jul 19, 2004 06:09 PM
