fly wheel queation
Old Jun 5, 2006 | 01:09 PM
vjace's Avatar
Default fly wheel queation
95 b16 dohc hydro trans
i know i should have a helms book but i searched also on the site for the torque spec on the fly wheel bolts that hold it their? i know the presure plate is 19 lbs
i looked it up at work but from the pic it says 87 lbs i think that is way too much for those tiny bolts any help would be great thank you.
Old Jun 5, 2006 | 01:19 PM
mugenhatchie's Avatar
Default Re: fly wheel queation (vjace)
The Flywheel to crank bolts are torqued to 87 ft/lbs the clutch to flywheel bolts are 18 ft/lbs. Hope that helps. Good Luck!
Old Jun 5, 2006 | 01:23 PM
Luserkid's Avatar
Default Re: fly wheel queation (mugenhatchie)
Put some blue loctit on them as well. 87 is just right unless you go aluminum then go with what the flywheel company says.
Old Jun 7, 2006 | 02:41 PM
vjace's Avatar
Default Re: fly wheel queation (Luserkid)
thanx guys
your awasome deff a must with lock tight lol
anzh86
Jul 27, 2010 09:04 PM
dadrought6
Feb 22, 2009 11:00 AM
vaypourus
Nov 9, 2006 06:26 PM
hotrodlincoln
Sep 26, 2006 04:10 PM
D16z6BoostedEK
Feb 3, 2006 11:42 PM
