00 gsr seat in 91 civic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Wonderful »</TD></TR><TR><TD CLASS="quote">will they bolt in w\o swapping rails? thanks</TD></TR></TABLE>
no
no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Wonderful »</TD></TR><TR><TD CLASS="quote">i dont have an ef or crx. someone who wants to buy these seats does. can he change the rails out or what. i am lost on the ef. i have an EK.thanks</TD></TR></TABLE>
my answer to the original question should answer this question as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89-civic-DX »</TD></TR><TR><TD CLASS="quote">You cannot swap the rails to make them fit.
Inorder to make it work he would either need to swap seat pans or cut and re-weld the tabs where the seats bolt down, so that it fits the ef chassis</TD></TR></TABLE>
not true. you can swap the rails, the seat pans will need to be modified.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">not true. you can swap the rails, the seat pans will need to be modified.
Actually you are correct, but in either case it is going to require some work and fabrication.
</TD></TR></TABLE>Actually you are correct, but in either case it is going to require some work and fabrication.
Actually you are correct, but in either case it is going to require some work and fabrication. </TD></TR></TABLE>
thanks, i know, i am always right
RMXmitch
Feb 22, 2007 06:12 PM
