Skunk2 pro2 cams won't idle! any suggestions?
Old Jun 5, 2006 | 10:58 AM
j spec's Avatar
Default Skunk2 pro2 cams won't idle! any suggestions?
just installed some skunk2 pro series stage 2 cams in a friends h22 and it won't idle. the bottom end is stock, head has been ported and has portflow valvetrain with ferrea valves. car drives fine after about 1500 rpm also vtec doesn't feel very strong (may not have anything to do with idle which is what im focused fixing). the car has proseries camgears set at 0 degrees.
Old Jun 5, 2006 | 11:09 AM
92TypeR's Avatar
FSAE
Default Re: Skunk2 pro2 cams won't idle! any suggestions? (roma's GSReg6)
You need to adjust the throttle stop on the throttlebody. This is NOT the idle control screw. Open it a hair by taking the throttlebody off and adjusting the stop until you can barely see light coming through the butterfly. The problem with large primaried cams is the idle-air-control-valve cannot compensate for the fluctuation of incoming air, and the idle surges. On B-series, they like 15:1 AFR and 21-22deg timing.
As for his power, you shouldn't judge by the butt dyno. What are you tuning with?
Old Jun 5, 2006 | 11:13 AM
j spec's Avatar
Default Re: Skunk2 pro2 cams won't idle! any suggestions? (92TypeR)
i'll try the idle screw. well its not my car its a friends im working on he has a shitty chipped p28 and a vafc. i told him the next cash he drops should be on an s200 so he is gonna do that asap.
Old Jun 5, 2006 | 12:16 PM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roma’s GSReg6 &raquo;</TD></TR><TR><TD CLASS="quote">i'll try the idle screw.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">You need to adjust the throttle stop on the throttlebody. This is NOT the idle control screw. </TD></TR></TABLE>
If you guys have decent technical skills you can use his chipped P28 to run something like Crome. Has the same functionality as Hondata but the software is free. This is what we use to tune all our customers.
Without fuel/timing control at idle, you will never get it to idle smoothly.
Old Jun 5, 2006 | 12:17 PM
mar778c's Avatar
Community Builder
Community Influencer
You should follow 92TypeR's insturctions.
Also, why waste money on a S200 when the ecu is already chipped and just needs to re-programmed via tuning.
Old Jun 5, 2006 | 12:26 PM
dkim48's Avatar
Default Re: Skunk2 pro2 cams won't idle! any suggestions? (mar778c)
just throwing this out there but did you do a valve adjustment after switching out the cams?
Old Jun 5, 2006 | 03:06 PM
ALLmotorTYPES's Avatar
Default Re: Skunk2 pro2 cams won't idle! any suggestions? (dkim48)
tuning is key
Old Jun 5, 2006 | 07:47 PM
an2ny888's Avatar
whats ur vacuum reading at idle with the pro1's on b series? i'm idling at 13 in'hg right now, quite low. also i tried the throttle stop adjustment but the idle goes too high , it reaches 1500 rpm
Old Jun 5, 2006 | 09:29 PM
92TypeR's Avatar
FSAE
Default Re: Skunk2 pro2 cams won't idle! any suggestions? (an2ny888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">whats ur vacuum reading at idle with the pro1's on b series? i'm idling at 13 in'hg right now, quite low. also i tried the throttle stop adjustment but the idle goes too high , it reaches 1500 rpm</TD></TR></TABLE>
Since the larger primaries shift the idle range out of the stock vacuum, you MUST use a full resolution tuning software like Crome or Hondata and adjust fuel to 15:1 and increase timing to 21-22deg.
You need to tune this while adjusting the throttlestop 1/2 turn incrimentally until you reach the desired idle. Every 1/2 turn you have to tune the idle again to the aforementioned air-fuel and timing.
Old Jun 6, 2006 | 06:36 PM
j spec's Avatar
well since its not my car im just gonna tell him to take it and get it tuned he has been wanting to put s200 on it anyway. i guess my jobs done. i hope i have better luck putting my pro2's in my gsr this week along with new timing belt and portflow springs retainers, i'll finally get to try out the 66 dollar ebay special valve compressor tool that seems kinda questionable.(it bolts to the head so i won't have to pull the head but its not designed like the majority of them)
quick99gs-r
May 25, 2009 06:35 AM
j spec
Dec 20, 2006 07:36 PM
j spec
Jun 6, 2006 06:23 PM
Teamdiesel
Jan 16, 2006 07:35 PM
cs_x21
Jun 25, 2003 03:54 PM
