B16 swap what else do I need
Old Jun 5, 2006 | 10:40 AM
crxpwr1's Avatar
Default B16 swap what else do I need
http://hmotorsonline.com/shop/...30002
If i get the mounts and the linkage from there what else do I need?
Thank you
Old Jun 5, 2006 | 10:44 AM
ludesrv's Avatar
I didn't click the link so I don't know what included but, engine and tranny, dizzy, ECU, clutch/flywheel, axles, mounts and shiftlinkage is pretty much all you need. Remember I didn't click the link so I don't know what the package was.
Old Jun 5, 2006 | 10:52 AM
SD_Lurker's Avatar
HT White Ops
Default Re: B16 swap what else do I need (crxpwr1)
You need motor mounts, shift linkage, rear L bracket, and if the axles are damaged you will need some different ones from a 90-93 integra. That about sums it up. You will also need to do a little wiring but not much. Any other questions?
Old Jun 5, 2006 | 11:03 AM
crxpwr1's Avatar
Default Re: B16 swap what else do I need (nicks_jdmstyle_ef9)
I have a crx dx so ima have to get the rear L bracket....and maybe axles....aright thanks...why will I need a little bit of wiring???
Old Jun 5, 2006 | 01:23 PM
crxpwr1's Avatar
wat kind of wiring will I have to do...
Old Jun 5, 2006 | 02:05 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
read the FAQ section dude..
You have to convert the wiring to MPFI and then add the wiring for VTEC..
Old Jun 5, 2006 | 02:07 PM
crxpwr1's Avatar
Default Re: B16 swap what else do I need (88DXCRX)
its obdo I thought u didnt have to convert it if it already is???....But ima go look at the faq and figure everything out and if i have any problems ill ask but can someone answer that one...if i have a dx and im gettin obdo why do i have to change it to mpfi...I know myne is dpfi
Old Jun 5, 2006 | 02:51 PM
88DXCRX's Avatar
To install an OBDO b16a1 you have to do a DPFI
to MPFI conversion..
You will need the four injector clips and the resistor box with it's wiring..
It will also help to find an Si type distributor plug off off the
engine harness.. Some of this should be included with the engine..
b16a1eg6
Feb 28, 2006 02:29 AM
jdmrider
Jun 23, 2005 09:07 PM
90crxdx
Feb 23, 2005 01:37 AM
mstrymxer
Sep 23, 2003 12:36 PM
90civichbsi
12
Jun 26, 2002 11:21 PM
