Would a 89 crx si odo will plug and play with 90-93 harness
Old Jun 5, 2006 | 09:47 AM
STP_crx123's Avatar
Default Would a 89 crx si odo will plug and play with 90-93 harness
i am making my research for a ls swap i wanted to know if the wire harness of my crx plug and play with a 90-93 ls harness
Old Jun 5, 2006 | 10:32 AM
E_F_9's Avatar
90-91.....92-93 is obd1 and your car is obd0
Old Jun 5, 2006 | 10:51 AM
Loserkidwac's Avatar
Default Re: (jdmef9si)
You don't need a new harness EF si harness has all the plugs you need, exten them as needed, the only one i had to extend was the fan switch sensor but thats because i was using a B18b and it located on the thermo housing instead of the back of the block...seriously save your self a headache and stick with your stock harness
Old Jun 5, 2006 | 10:54 AM
SD_Lurker's Avatar
HT White Ops
Default Re: Would a 89 crx si odo will plug and play with 90-93 harness (STP_crx123)
Tell me you did not buy that CRX.
Tyler Gardner
Jan 27, 2013 09:44 PM
tree fingers
Jun 22, 2012 08:34 PM
jordy75
Aug 9, 2010 02:51 PM
duckmanEG
Mar 21, 2007 12:52 PM
G0crxG0
Jun 30, 2006 12:50 PM
