ABS and BRAKE light on cluster were on!!!
Here's the scenario of my car problem. The car is 95 GSR 140,200, anyway, last night my car won't start, I just heard it clicking but not turning at all. After trying so many times, my car finally started. After it started my BRAKE and ABS lights on cluster were on and the car sounds funky. I drove the car home with the BRAKE and ABS lights on cluster on, and when I turn off the car and take the key out from the ignition the car is still running. So I put the key back to the ignition and crank it again and shut if off again and the car shut off finally. Then this morning my car won't start again, turn the key so many times (I turn the key up to II) and I finally make it to start, and the BARKE and ABS lights are gone. What do you think the problem of my car. I really need some advice.
sounds like an ignition and/ or wiring problem
I would check your cap, plugs, plug wires and rotors
also try cleaning your ABS sensors
if that does not work I would take it to a wiring specialist
EL TYPE R
Dec 22, 2016 12:28 PM
B16aEk4drbeater
Nov 17, 2012 06:14 AM
