camber kit needed for 2.25 inch drop ?
Old Jun 5, 2006 | 03:13 AM
redDAinteg's Avatar
Default camber kit needed for 2.25 inch drop ?
do i need a camber kit or can i just set the toe to 0 ?
Old Jun 5, 2006 | 03:41 AM
GSR-Street Racer's Avatar
You're going to need one since camber is definately going to be an issue with that kind of drop. You don't want to go through new tires in less than 6 months.
Old Jun 5, 2006 | 07:54 AM
iH8RICERZ's Avatar
Default Re: (GSR-Street Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-Street Racer &raquo;</TD></TR><TR><TD CLASS="quote">You're going to need one since camber is definately going to be an issue with that kind of drop. You don't want to go through new tires in less than 6 months.</TD></TR></TABLE>
i dont know how you drive or what tires your rollin on but tires last me over a year with a 2.5+ drop on my DC2. Camber isnt as bad as the ek/eg/da chassis. Of course, if you would like your tires to wear evenly, then get a camber kit. I've been rollin without one for the past 6 years. Sure my tires wear a little faster on the inside, but its not all that bad, unless your using a soft rubber compound (falken azenis for example)
edit: just realized your probably have a DA....... you'll probably want to get a camber kit if you go any lower than 2.5".....I'll let other people with DA's can chime in.
Old Jun 5, 2006 | 10:34 AM
rkrone's Avatar
Default Re: camber kit needed for 2.25 inch drop ? (redDAinteg)
get a camber kit- also safety first, you will have better control
Old Jun 5, 2006 | 10:36 AM
__oversea's Avatar
Default Re: camber kit needed for 2.25 inch drop ? (rkrone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkrone &raquo;</TD></TR><TR><TD CLASS="quote">get a camber kit- also safety first, you will have better control</TD></TR></TABLE>
and even tire wear. safer in rain.
Old Jun 5, 2006 | 12:38 PM
TunerN00b's Avatar
Default Re: camber kit needed for 2.25 inch drop ? (Last For One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Last For One &raquo;</TD></TR><TR><TD CLASS="quote"> and even tire wear. safer in rain. </TD></TR></TABLE>
Normal tire wear can be achieved with correctly set toe. I would wager that safety in rain has more to do with tire design, than camber setting.
I daily drive my Integra lowered around 2.25", with -2.7* front camber, and tire wear is not a problem. I also drive my Triumph Spitfire with -4.75* rear camber, and in 10k miles, it isn't showing any signs of abnormal tire wear, even without any tire rotations at all. RWD and -4.75* rear camber, perfectly even tire wear. Could also have something to do with the 155/80-13 tires I suppose.
Old Jun 7, 2006 | 12:50 AM
redDAinteg's Avatar
Default Re: camber kit needed for 2.25 inch drop ? (TunerN00b)
so i dont have to do anything with the toe? just camber ?
Old Jun 7, 2006 | 06:21 AM
juicy.fn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg &raquo;</TD></TR><TR><TD CLASS="quote">so i dont have to do anything with the toe? just camber ?</TD></TR></TABLE>
no no no...when you lower a car, first thing that needs to be done is an alignent. Have them set your toe to factory spec.
second, I personally would recommend getting a camber if you are dropped that low. That is if you want to save tires a little longer. I know people will say its not necessary but my car is a daily driver and I just dont want to go through tires like cake.
Also I get an alignment that sets my toe and camber to factory spec every 6 months. its nice to have a lifetime aligment at Firestone. Only paid $160 and its unlimited. Mine has been paid off since ive gone about 5 times. They are about $50-$60 a vist, do that math.
Old Jun 7, 2006 | 06:40 AM
__oversea's Avatar
without camber kit / \ &lt;-tires from rear or front view, l l &lt;-toe on 0'.(from bottom view or top).
but for 2.25 drop, camber isnt that big. do the washer trick on the back for money save.
Old Jun 7, 2006 | 10:03 AM
Adambomb's Avatar
I personally would get a camber kit.
Not only do your tires last a little longer and it's more safe, IMO it looks better.
Beeda
Dec 13, 2007 05:28 PM
ezol
May 24, 2007 01:38 AM
98savage
May 15, 2007 01:13 PM
Tuesdaynightfever
31
May 24, 2006 06:03 AM
SF_EF8
Suspension & Brakes
Mar 30, 2006 12:05 PM
