Bigger brake setup for Turbo CD5 Accord..
* B A N N E D *
I have heard that you can upgrade the front brakes on the 94 Accord EX (That I have) to 95 Prelude rotors and calipers... I was told that they are larger diameter, and that everything bolts on.
Is there anything I should know about the swap before starting to look for parts???? Has anyone done this before???
Also are there any other brake swaps that are doable.... Keep in mind that the EX has the ABS setup....
Thanks for your help guys
* B A N N E D *
The legend stuff is bigger than the prelude ****???? Still 4 lug right??? Do you know size???
THANKS MAN!!!
THANKS MAN!!!
same bolt pattern on the discs if you stick to 94 gs. anyway, we just take the calipers and put them on.
yes, bigger pistons, and 2 of them. You can use Prelude discs with them.
do the legend piston upgrade and then get something like brembo blanks or powerslot discs or something the link for the legend up ^^^ but ill post it again https://honda-tech.com/zerothread/1620413
and to answer the other question the smallest wheel size you could use is 15" depending on the size of disc of course
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OuttaGas »</TD></TR><TR><TD CLASS="quote">whats the smallest wheel you can use after this upgrade?</TD></TR></TABLE>
If you go with the AccordV6, Prelude, Legend, ect upgrade with the 11" rotors then 15" is the smallest you can go.
If you go with one of those big brake kits that some companies sell, your most likely looking at 17" as the smallest.
straightshot08
Jun 24, 2009 04:20 PM
Westrock2000
Mar 29, 2002 07:01 AM
